Are there an other air mouses that have a headphone jack in it, which would work with the Minix x7.
Minix Neo X7 - Finless 1.4 ROM - with FIRST 1080P kernel and vsync fixed!
Here is the link for Android 4.2.2 - Minix Neo X7 - Finless 1.4a ROM with 1080P or 720P
ROM -> Minix Neo X7 - Android 4.2.2 - Finless 1.4a ROM (278 megs)
Bob,
Thank you very much for the ROM.
I was able to flash this Rom instead of stock Rom that came with device.
I must admit it is one of the finest, free flowing UI I had in long time.
My network connection both thorough WIFI or thorough Ethernet has been excellent.
I really been enjoying the device.
Thanks to you and Minix for this wonderful device.
Originally posted by skeletalspore View PostHow is the Mele F10? (not the pro version)
Sorry Skelatal, I have never used the F10, just the F10 pro, not sure what others have headphone jacks
Minix has confirmed that they have changed something with the bug in FW 0004 (on their forums), which will be released shortly. Hopefully it is fixed.
Originally posted by Finless View PostDamn! This is going to keep me busy. I will try to update Friday.
I would like to hear about any issues that show up on this new FW so I can look into it.
All over WiFi not ethernet
Originally posted by Bigleg View PostI'm on their forum talking about this, they are working on the sleep/off power bug, not the random shutdown, they say they have not witnessed this problem
And I have not had a single unexplained or unexpected power-down. In fact quite the opposite for my x7, it seems quite hard to actually power it down. And I have had to unplug the cord several times as the last resort to get a fresh reboot.
I have compared Hobbit 720p (7gb) with this rom and WDTV live gen 3 with 24p setting on my Sony tv many times now. My conclusion is that it is still quite amount of frameskipping/stuttering left on Minix X7. I used Archos and MX player from internal memory in my test.
If WDTV is like 99% perfect i would say that Minix X7 is around 80%. Also tested alot of other mkv with same diffrence between the two. But Hobbit is great to test when flyby over map in the beginning it is very easy to see if it is smooth or not.
Originally posted by pawnslinger View PostI run exclusively thru wifi, but I have left ethernet enabled in the settings (as all my other devices are, i.e. TV, bluray player, etc... the ethernet port on them is always enabled, even tho I don't use it).
The more I think, always using an app that is using a mount or network location of some description.
NEO X7 004 firmware
DO NOT DISCONNECT THE POWER AFTER RESTORING,
WAIT FOR AT LEAST EXTRA 5 MINUTES TO ALLOW FULL SYSTEM RECOVERY.
MINIX NEO X7 20130822 (version 004) 4.2.2 firmware
Release Date: 2013-08-22
Change log:
1.) Fixed Factory data reset bug;
2.) Fixed mouse unable to wake up event;
3.) Fixed shut down bug, added blinking sleep status LED;
4.) Added HDMI and SPDIF passthrough options;
5.) Improved DDR stability;
6.) Added support for Logitech C525, C920 web cameras;
7.) Fixed screenshot bug;
1080 kernel version will come up if you guys are happy and feel OK with this version!
Original post: NEO X7 004 firmware (22nd August) | MINIX Forums - Unofficial"Success is a lousy teacher. It seduces smart people into thinking they can't lose."
- Bill gates
There are currently 2013 users online. 1 members and 2012 guests.
