H96 pro + Ultra 4k
Not sure now, as it was month ago. Around 20 minutes if I remember it right.
If SCV4 doesn't work, than SCV7A won;t boot either.
Try to boot to TWRP - disconnect power cord, push reset, connect power, keep pushing few seconds or till TWRP logo will be shown and do Fastory reset (Wipe->swipe). Than reboot.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
There is option to Factory Reset using Settings, but as You don't have access to working OS, than You can use TWRP. It's same thing.
I even prefer using TWRP as I had problems with settings Factory Reset option in the past.ALFAWISE H96 Pro+ 3/32 (S32-V6) | 7.1.2 | SCV7A | OC kernel | TWRP 3.1.1-0 | 64GB
Originally posted by marponz View PostToday I try rom 20171206 on my ZH01-S912-TVBOX-V3.0, and it dont run. I must go back to my old rojm
marponz What ROM are you using that does work, when you say going back to your old rom?
Originally posted by marponz View PostI gone back to wisdom rom.
Originally posted by Lakuma View Post
Is this the Wisdom ROM that you are using?
There are currently 3151 users online. 0 members and 3151 guests.
