yes it did show a weird grey bar and which froze the box. I disconnected from power and restarted again, but this time I kept the reset button pushed for the complete flashing process (Which then proceeded correctly)
H96 pro + Ultra 4k
Originally posted by seryser View Post
Esase Bootloader checked or unchecked? this is giving me a headache
Originally posted by marponz View PostHi friend. I have a H96 Pro + ultra 4k device. When I use aida apk, it tell me : alfawise with 3gb DD3 and chip wifi q9377. I opened my box and I see on pcb ZH01-S912-TVBOX-V3.0, made 2017-09-09. My device has many bugs and so I need to change the rom. I dont want to brik it. Please can you help me to decide about the new rom to update. Thanks a lot tof
Hello, can you tell me what errors it gives you? I have tried several with this version and it does not give any errors at the moment. Thanks and best regards.
Originally posted by Mss81 View Post
Hi marponz ,
I did get a link and instructions to flash it through USB burner, but that didn't work. Then I applied a version from September through USB burner which did work which I can use as backup for this box:
But after flashing this firmware I did successfully flash Supercelerons ATV rom SCV1 through SD card (using Burncard Maker). Initially the flashing stopped at the very beginning, but the I kept the reset button pushed during the whole flashing process. Eventually the box rebooted, but the screen was flickering --> this was fixed by reconnecting the HDMI cable.
The SCV1 worked smoothly and had no big issues, I only didn't like the interface. So I applied the SCV4 OTA update through TWRP (just put the OTA zip unpacked on a SD card, boot into TWRP recovery and apply the update).
This is also working fine now, only just during the first boot the system was unresponsive for a long time and I had to uninstall the google play store updates.
So on this SCV4 all is working OK:
- WIFI
- Ethernet
- Bluetooth
- HDMI CEC
- NO randoms reboots and NO freezes
Only thing not working is the Power on from full shutdown. I have to unplug the power and reconnect it again. (By default the box goes into sleep mode which is fine as well,restart with HDMI CEC or remote)
But overall the SCV4 version is far much better than the stock rom Wisdom version.
The different manufactures used several PCB designs. You would have received a Wisdom PCB and factory firmware is limited(2?)
Maybe Shonks efforts may help
or
A versitile firmware like Frankenstein v2 - v3
UPDATE June 2020. ????? (Likely for 2/16 ram/rom)????? aml_7.12 s912 Frankenstein 3.2 (AOSP 64 bit) Lite version... 426MB size (ATV only...?). & aml_7.12 s912 Frankenstein 3.3 (AOSP 64 bit) Full version... 492MB size (ATV only...?). aml_7.12 s912 Frankenstein 3.3 (AOSP 64 bit) Full LP version... 617MB size (ATV
There are currently 2542 users online. 0 members and 2542 guests.
