[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Hello. Newbie here. If I install this rom and I don't like it / doesn't suit me, is it possible to return to the the original version ?
Of course you can. However, there's a bug in the OEM update script that prevents it from installing from TWRP. Use this "fixed" version instead: http://freaktab.org/a0d8140afad9d0f1
Hello, I am quite new... but studying...i have a X96 Mini, I was able to install the T3x mini today and the m8s pro stock... but I get the "USB control setup error" when I try to use this rom with Amlogic USB burning tool... So.. sorry to bother.. what am I doing wrong? I would love to have a Tvstock rom and I see that somebody was able to install this one on the X96 mini. Best
Hi!
It would be really nice if you could change the target device and port the rom for the tanix tx3 mini or any s905w box
If some one know to change it I really appreciate the info.
Greetings
My plan is to adapt the Tanix T3 Mini firmware, since it has support for many wireless drivers and IR remote controls. The problem is that they downgraded the UI to 720p, and I'm not willing to make that sacrifice. If VideoStrong can do 1080p on the S905W, then Shiningworth should be able to as well.
There are currently 2040 users online. 0 members and 2040 guests.
