[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Guest Thanks for u replay
I really appreciate your work.
I have already installed your rom in my tx3 mini through de update zip, I delete the validation from the script and signed again.
Its smooth and stable, only wifi and remote doesn't work (i don't really care about this).
But I can't solved the netflix black screen error.
There is a 1080 versión for the tx3 mini based on last release
#s905w , thử làm những cái mà bên nhà sản suất không làm , hoặc không dám làm :) Firmware chạy UI Full HD 1080p cho TX3 mini Rom stock Ai dùng thì cho phản hồi ở đây nhé ....
I hope help you
Greetings!
To begin with I will say Magendanz thank you for this project.
Unfortunately I came across that there are problems, I list.
In the Settings in the More section, when you click on any options, you get the following:
Setting has stopped
-open app again
-Mate until device restart
What does it mean?
Guest
Changelog (20180121):- Updated to the latest Mecool M8S PRO W OEM firmware (20171030.152444.V0619),.
- Fixed bug causing panels within classic Settings (Settings->More Settings) to crash.
- Updated to TWRP Recovery 3.2.1-0 with latest OEM kernel.
- Updated to latest OpenGApps build (20180121).
- Wake from sleep will result in a restart. This seems to be a bug in the underlying OEM firmware, one VideoStrong is in the process of fixing.
- Google Cast service works from Chrome browser, but apparently requires Google license to work from Android apps.
- TVStock Variant: BURN PACKAGE (0.97GB IMG file), OTA UPDATE (529MB ZIP file)
Hi Magendanz, I really appreciate your work and I'm very enthusiast of this rom, but I have a little problem with the Italian app timvision. This app has contents like films, tv series etc, when I try to start something I get the message "this device does not support the required drm scheme".
Can this be solved in somehow?
thank you
Originally posted by Magendanz View PostChangelog (20180121):- Updated to the latest Mecool M8S PRO W OEM firmware (20171030.152444.V0619),.
Guest of course :-)
it actually looks fine, but the test patterns show it as 720p
also, any ideas why sometimes (on the netflix app) sound and and video are not synchronized?
I've heard it happen on the mi box too, so maybe an android tv issue? just thought i'd askLast edited by alexm231; 27 January 2018, 11:35.
hello Guest
First of all, thank you for your great work about this rom ! works well on my x96mini (exept wifi and remote )
my question is if i buy a wifi remote control, with a micro does it gonna work ?
the apk of android remote work well, (the mic too ) but i don't want to use it ( uncomfortable for me )
thanks for your reply
kenwyz
ps:i juste notice that THE WIFI IS WORKING on my x96mini !!!
can you belive that !
Hello Guest ,
I want to buy M8S pro W or L (can't decide yet). But I wonder if I can install facebook, instagram, twitter on these boxes? I must install them, and will be used everyday, I want make my small TV as a tablet for my wife. Can I make it with these tv boxes?
She must explore facebook/instagram/twitter etc..
thanks...
There are currently 1655 users online. 1 members and 1654 guests.
