[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Originally posted by pagasios7
the problem is the reset button.
i try to update this rom with burning tool and i cant find the reset button om my tv box to conect with my laptop.
i open the box anf i find the two pins without results.
also try "reboot update" in a terminal window but i dont know the method.
Enviado do meu Redmi 4X atrav�s do Tapatalk
Originally posted by Tiagosantos View PostI'll help you, format the box on settings and download the Ota update onto USB rename it to update.zip and install from updater app local! Its just Simple like that!
if you can to give me more info for the process plz
he,he yes
i do it.
but when rebbot in recovery mode say error.
this 2 problems
e:footer is wrong
e:signature verification failed
Enviado do meu Redmi 4X através do Tapatalk
Guest
Hi all, I am a new user of an android box and I am using the android TV custom rom. I want to use my device for kodi, Netflix and also to download stuff. Is there a torrent client which I can use and also control from my Windows pc? Thanks
Originally posted by netloggerI am now using OEM stock, will try your's in a few days. I'm trying to learn device, I try many things now. It will be all erased when install new firmware. I now can use 2 youtube versions at same time.
There are currently 3065 users online. 3 members and 3062 guests.
