[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Those who are eperiencing the HDCP problem and can't play netflix. This is the only solution:
It is a problem that your HDCP protection codes are erased or corrupted. Then you must have the original codes, and you must write them to the box. This can be written with adb and you must have the original code package for your box only.
You can request this code package from the seller, or from mecool. I or any other can not give them to you. It is related to your box's serial number. Then the only way is request it from the seller...
Originally posted by netlogger View PostFriends,
Where can I find the latest original mecool firmware? I do not want nexus or other versions. I need the original one? I have M8S PRO W-ota-20171030.152444.V0619-fixed.zip file. Is this the latest one?
Originally posted by jajoness65t View PostJust want to say thanks to Magendanz for this ROM.
I flash this ROM on a W95 box (https://www.gearbest.com/tv-box/pp_736117.htmlbox) that I been using for the past month. Everything worked fine apart from the remote that no longer work which I can live without.
I flash it the USB Burning Tool way and it flash without any error. It work much better than the original firmware that came with it.
Originally posted by red dwarf View Post
Go to the first post. The link is under change log 20180311. The version is 20180126.
but I tried that, it is not mecool launcher, it has Android TV launcher.
I want firmwae with original mecool launcher(the white background). Do I make something wrong?
thanks,
Enviado do meu Redmi 4X através do Tapatalk
Hello all, can anyone help me to figure out which m8s I have? I bought it july 2017 and I am pretty sure its not l or w. It was flashed with different firmware so that option is out. It never worked without crashing so getting it running would be great.
The specs are:
OS:Android 7.1 OS (Latest Version)
CPU:Amlogic S912 64 bit Octa core ARM Cortex-A53 CPU up to 2 GHz
GPU:ARM Mali-T820MP3 GPU up to 750MHz (DVFS)
SDRAM: 3GB DDR4
FLASH: 32GB EMMC Flash
WiFi:Built in 2.4G/5G WiFi Support IEEE 802.11 a/b/g/n/ac
Blutooth:Bluetooth 4.1+HS
LAN Ethernet:100MRGMII
Video decorder:H.265 4K @60fps 10btis, VP9 Profile 2, H.264 4K @30fps, AVS+ 1080P @60fps
Video encorder:H.264 1080P @60fps
HDR:HDR 10,HLG HDR
Decoder format:HD MPEG1/2/4,H.265/HEVC , HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10
Media format:Avi/Rm/Rmvb/Ts/Vob/Mkv/Mov/ISO/wmv/asf/flv/dat/mpg/mpeg
Music format:MP3/WMA/AAC/WAV/OGG/DDP/TrueHD/HD/FLAC/APE
Photo format:HD JPEG/BMP/GIF/PNG/TIFF
Network Function:Miracast,,Airplay,Skype chatting,Picasa,Youtube,Flicker,Facebook,Online movies,etc.
Language:English,Chinese,Germany,Japanese,Korea,et c.24 languages
Thanks for any help.
Originally posted by IceflareHello all, can anyone help me to figure out which m8s I have? I bought it july 2017 and I am pretty sure its not l or w. It was flashed with different firmware so that option is out. It never worked without crashing so getting it running would be great.
The specs are:
SDRAM: 3GB DDR4
HDR:HDR 10,HLG HDR
Hello all..
I bought the M8S pro W, with old remote (without ATV).
I installed this firmware latest version, but two things ate least dont work:
- cast
- pair with google home (gives an error of a missing framework)
I think something is broken (cast related?!?) that causes both errors.
Can someone confirm this? Is there any fix or workaround ?
Thanks!
- cast
Thanks!
For cast look for airscreen APP on PlayStore i try'd myself
There are currently 1757 users online. 1 members and 1756 guests.
