Enviado do meu Redmi 4X através do Tapatalk
[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
I have M8S pro w, it came with preinstalled latest firmware 20180307, but i feel that is very sluggish and slow in work, can i downgrade to some stock firmware that has better performanse? Could you advise? I tried ota 20171030 to flash from zip but it sayed "error too old version"?Last edited by Jole; 24 May 2018, 08:59.
I have the box meecol m8s pro w, the software version is 20180312.181951.v0213 (original version) and I have the following problem: sometimes the box freeze, usually after some time on ,after freeze, i turn it off and on again and continue to operate. What do you advise to do? Do you think it's a rom problem? thanks
Originally posted by Blindado View PostPode me ajudar?
M8S PRO W USB Upgrade Guide
1. Copy the upgrade files to the root of TF card or USB device. (Tips: TF card or USB device file system must be FAT32 format)
2. If use USB device to upgrade. Plug it into the OTG host of the box.
3. Switch to APPS List, Find out the “UPDATE” application, and Press OK Key into sub-menu.
4. Move the cursor to “Local Update” button, Press OK key to select the upgrade file. To be find out the upgrade file and Press OK key to confirm.
5. Select the two checkbox of wipe data and Wipe Media. Move the cursor to “ Confirm” button and Press OK key to upgrade
6. The upgrade process will take 3mins approximately. Please don’t power off during the upgrading . After upgrade finished, the box will reboot automatically.
Hello. I bought a tvbox mecool m8s pro W voice control. has already come with downloaded androidtv. I uploaded soft from Nexus and the voice search was stopped and the remote control was not able to enter on the screen keyboard. I uploaded through burning Rom some old original Rom without android tv. what is the proper working voice control with androidTV?
There are currently 2914 users online. 3 members and 2911 guests.
