[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
now i'm able to use the burning tool.
i chose another usb port and the device get found.
but now i have another problem. i flashed this image: https://androidfilehost.com/?fid=5862345805528063098
now the box stuck at the bootscreen
what could i do?
Originally posted by SebastianS1987 View Postnow i'm able to use the burning tool.
what could i do?
Hello .. Good night. I have 1 mecool m8s pro w and I downloaded the version M8S_PRO_W-ota-20171017.112143.V0619 and updated by the sdcard and when the update finished nothing appears on the TV is the black screen. I try to make recovery from usb burning tools 2.0.8 and it gets an error when it reaches 7%.
marcosjeovan
Just download ROM in post 240: https://drive.google.com/file/d/1ZKu...p6S74nW5R/view - and follow the procedure I described in post 253...
1.First flash "M8S_PLUS_W 20180622.img with usb burning tool after flashing start your Box., it will be strange but do not worry...
2. Than in PRO W - folder put this 2 files on USB stick (M8S_PRO_W-ota-20180312.181951.V0213.zip and recovery.img) and go to Local update... find this M8S_PRO_W-ota-20180312.181951.V0213.zip file and flash
- or instead of this zip you can download this one and do the local update... - but important part is that zip file and recovery.img must be together on usb stick side by side or you will brick your Box again...
http://legion.name/upload/Smart-TV-B...2556.V0213.zipLast edited by sappy; 21 October 2018, 22:41.
@marcosjeovan
marcosjeovan marcosj Does this rom present keyboard problems ??? because I installed this post and I faced problems with the virtual keyboard .... Are you Brazilian?
There are currently 1064 users online. 0 members and 1064 guests.
