[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Originally posted by ghaliharisma View Post
Originally posted by Novato View Post
Unfortunately, so far I do not know of any firmware compatible with your device. However if you find the initial interface HORRIBLE, just as I hate it too. You can change the Default Launcher for Alice UI from Tanix, I did it on my M8S Plus W and it was great. I'm currently using the Android TV OS Launcher, but I still really like the Tanix launcher.
Originally posted by chmurson View PostMy unbrick procedure (m8s pro w) - black screen, only red led.
We need male-male usb cable, I was made from two generally available microusb cables.
Just cut them in half and connect wires one-to-one (red-red, black-black, green-green, blue-blue)
1. Run the USB_Burning_Tool program
2. Connect the power supply to box and USB cable to port closer to the power plug (only this port working as modem)
3. The program should detect the device, and You can proceed to upload img.
The matching firmware is M8S_PLUS_W 20180622.img, others stopped at 7% with an error
4. After uploading the firmware, resetting the device, the first start takes a few minutes.
My M8S PRO W has changed to PLUS W ;( and install some wird software (but finally work!!!!)
5, To fix this you need to follow the guide:
https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905/others-ac/firmware-roms-tools-bj/752605-rom-oem-mecool-m8s- plus-in-android-tv-to-videostrong
After flashed, the first start takes a few minutes. TADA!
We enjoy pure androidtv (not some Chinese junk soft)
I have bought M8S PRO W in the past and had no issues flashing the ATV from this page , but this time seems M8S PRO W is different revision and just gave blank screen so did what you did and got it working again flashing firmware is M8S_PLUS_W 20180622.img
but i cant get the ATV rom to flash following
when i flash the M8S Pro W ATV OEM Firmware using OTA I get the following screen do you know what i am doing wrong i followed the steps to change date and saved
Originally posted by uscool View PostI got it working just changed other lines which also showed dates and flashed fine, note to others the ATV rom here wont work on new revision Mecool M8S PRO W 2.4G with Andriod TV
Thank you for all the info very grateful
this is so weird. i have x96 with S905W 1GB they are not as slow as mecool M8S Plus DVB with S905D
does S905W better than S905D ? Guest
Probably this depends on the firmware. The truth is that a box with 1GB of RAM will be as bad as a Sangung cell phone with 1GB of RAM and various apps like Facebook, Instagram and Messenger installed and running in the background. Unless you limit all RAM usage and use optimized apps, performance will be poor indeed.
Is there a way to install this rom on this version https://www.amazon.it/Telecomando-Mi...ords=m8s+pro+w of the device?
Guest
ghaliharisma
I guess the firmware is absolutely crap. I've bought an MX Allwinner H3 box, advertised as 2GB but actually 1GB of RAM. That box is awesome in speed, really!! No comparison to Mecool M8S pro/plus W...the Allwinner H3 feels like 3GB RAM...
Hi All
I have another problem with box.
Ethernet not work in this rom.
In adb shell eth0 exist (have some mac addres, etc), but when i plug cable in device there is no connect (no led in switch, etc).
I try difrent cable (cross, normal), diffrent switches (100Mbps, or 1Gbps) - no connect.
Any advice to wake my ethernet (i prefer cable connet because i have little laggy wifi connection)
Code:M8S_PRO_W:/ $ su M8S_PRO_W:/ # whoami root M8S_PRO_W:/ # ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 4096 qdisc noqueue state UNKNOWN group default link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000 link/ether d0:76:58:10:cb:1b brd ff:ff:ff:ff:ff:ff inet6 fe80::d276:58ff:fe10:cb1b/64 scope link valid_lft forever preferred_lft forever 3: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default link/ipip 0.0.0.0 brd 0.0.0.0 4: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default link/sit 0.0.0.0 brd 0.0.0.0 5: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default link/tunnel6 :: brd :: 10: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 58:04:54:c1:1c:37 brd ff:ff:ff:ff:ff:ff inet 192.168.0.101/24 brd 192.168.0.255 scope global wlan0 valid_lft forever preferred_lft forever inet6 fe80::5a04:54ff:fec1:1c37/64 scope link valid_lft forever preferred_lft forever 11: p2p0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000 link/ether 58:04:54:c1:1c:36 brd ff:ff:ff:ff:ff:ff M8S_PRO_W:/ # ifconfig eth0 Link encap:Ethernet HWaddr d0:76:58:10:cb:1b inet6 addr: fe80::d276:58ff:fe10:cb1b/64 Scope: Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:8977 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:2606 Interrupt:40 wlan0 Link encap:Ethernet HWaddr 58:04:54:c1:1c:37 inet addr:192.168.0.101 Bcast:192.168.0.255 Mask:255.255.255.0 inet6 addr: fe80::5a04:54ff:fec1:1c37/64 Scope: Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:25793 errors:0 dropped:0 overruns:0 frame:0 TX packets:21497 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:30448627 TX bytes:3152130 p2p0 Link encap:Ethernet HWaddr 58:04:54:c1:1c:36 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 TX bytes:0 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope: Host UP LOOPBACK RUNNING MTU:4096 Metric:1 RX packets:7970 errors:0 dropped:0 overruns:0 frame:0 TX packets:7970 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:1278004 TX bytes:1278004
There are currently 1832 users online. 0 members and 1832 guests.
