[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Hello All,
This is an update of installing this ROM. Please review my earlier details of this box here:
What is NOT working:
- Known issue. Installed Netflix from Play Store and is giving this error. (Sorry could not reach the Netflix Service. Netflix (-100)). Will install older version of Netflix and shall update.
What's working:
- Remote is fully working
- Wifi is working
- Youtube and KODI are working in 1080p
- This ROM is rooted and have TWRP Recovery v-3.2.3-0
Question:
- How to disable advertisement in youtube app?
My TV Box:
Code:[I]CooleMe[/I] CM-MM1 (It is a clone of Mecool M8s pro W) Board: p21x 2GB/16GB Print on the Blue PCB Board: M8S_W_REV1_0 2017-08-19
ROM File Name: M8S_PRO_W-V0213_TVStock-20190216.img
I have installed this rom via Burn Card Maker (an alternate method) and it was successful. (https://chinagadgetsreviews.com/down...er-v2-0-2.html)
This is the setting of the Burn card Maker while writing this ROM on a SD card:
Steps:
- Start the box in the Stock ROM
- Enable Developers Option (https://android.tutorials.how/enable-developer-options/)
- Connect to this box via adb over TCP
Code:C:\opt\adb>adb connect 192.168.1.250 connected to 192.168.1.250:5555 C:\opt\adb>adb devices List of devices attached 192.168.1.250:5555 device C:\opt\adb>adb reboot update # to install this Nexus ROM
part of build.prop
Code:# begin build properties ro.build.id=NHG47L ro.build.display.id=M8S PRO W-userdebug 7.1.2 NHG47L 20180827.121904.V0213 ro.build.version.release=7.1.2 ro.build.version.security_patch=2017-12-01 ro.build.date=Mon Aug 27 12:19:03 CST 2018 ro.build.type=userdebug ro.build.user=magendanz ro.build.host=freaktab ro.product.model=Nexus M8S PRO W ro.product.brand=Amlogic ro.product.name=p21x ro.product.device=M8S_PRO_W ro.product.board=p21x
Futher update re: Netflix.
I now have installed Netflix app from here and Netflix is working with this ROM. This only plays NETFLIX in SD and not HD.
atvxperience.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf atvxperience.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Many thanks
Question: I have Netflix HD subscription. Is it possible to play NETFLIX in HD please?Last edited by hannah; 22 April 2019, 01:39.
Originally posted by kolinsb View PostHi Guest . Is your firmware compatibile with blue PCB board v2.2? On box is installed this fw version: 20180724.093649.V0213. Tnx in advance!
USB Burning Tool v2.0.8
https://onedrive.live.com/?authkey=%...&action=locate
OTA UPDATE:
Thanks for reply. I installed this firmware. And YES, this firmware has problem with WiFi too, as originaly firmware. After some time of using WiFi, download speed drops for more ~60%. My connection speed is 20/2Mbps. After I used box for some time (watching youtube, using kodi etc), WiFi download speed drops on 5-7Mbps, and only solution (for some time) of this problem is to reset WiFi (disable/enable Wlan card). Prove for this problem is video I recorded. First, speed test show download speed of 6-7Mbps. After I reset WiFi, speed back to normal (~20Mbps).
Hello guys just wanted to ask i have a mecool m8s pro W and the firmware on it is 90636038 in settings it says 7.1.2 version! how can i upgrade the firmware? what can i do? thanks!
There are no Oreo or Pie OEM ROMs for the M8S PRO W, at least not that I've seen from VideoStrong. In fact, Amlogic's ongoing SDK support for the S905W is hard to determine, since it's not showing up in their tables: http://openlinux.amlogic.com/Android/Mbox
Hello!
Magendanz I installed this ROM and works 30 times better than stock one that I had, no freezing or anything else (mega deep sleep when inactive) now so thank you for that!
But the problem is TWRP, i cant find single TWRP which works, even tho one comes with ROM, I cant mount anything in TWRP. I tried some from other posts here but same result.
I swipe the bar to allow system modifications, I get in TWRP menus and stuff, everything is clickable but it cant mount system,data etc., and when im rebooting to system it says no OS detected, but still boots to my OS.
I read through most of posts but people usually talk about REV 2.2 which i dont own. Is there any workaround or TWRP which i missed?
I have blue board REV 1.4 , july 2018.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 3424 users online. 0 members and 3424 guests.
