Enviado do meu Redmi Note 5 atrav?s do Tapatalk
[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Originally posted by apotsi View PostDidn't get the last part. Is there any guide ?
Originally posted by Tiagosantos View PostDownload an .m3u list of channels install tvirl from play store you'll see live channels app now on homescreen, now Open tvirl app and configure it select the .m3u list you download and now live channels Will work
Hi Magendanz,
I took burn package and I manage to install this rom. But this is not a TV OS. This is the Nexus android os , isn't it?
I did something wrong? because I can see any environment like the images in your first post.
Can you please help me?
Thank you in advance
I use TV Stock Rom from Magendanz. I had read that m8s pro w has L1 DRM so I tried to install Netflix (TV version) but with no luck (error -100). Nether old ones.
Version 4.9 of Netflix for tablet or phone works but only with SD resolution. Despite that this version of Netflix is impossible to put it on the home screen.
Generally, I understood that if you want Netflix HD , DON'T buy tv boxes like mecool or any other similar device. Just go straight to Fire stick TV or Xiaomi Box or something like this.....because 2 days now I'm reading and reading articles to fix this with Netflix HD and all of them are fake.....No one can give you the solution or a straight answer : Can Mecool m8s pro w plays Netflix HD? and if yes how?
Hello Magendanz, I use this M8S_PRO_W-V0213_TVStock-20190216.img. TWRP Recovery 3.2.1-0 with the latest OEM kernel does not work properly so I returned the original recovery. ROM works fast and stable and I'm happy with it.
I just verified that it boots to TWRP with no errors after flashing my original M8S PRO W with the 20192016 burn package, and the restore.img in the OTA update is identical. Could you elaborate more on "does not work properly" so that I can try to reproduce the problem here? Also, which hardware revision are you using?
There are currently 1900 users online. 1 members and 1899 guests.
