USERS WAITING EMAIL CONFIRMATION THAT HAVE GMAIL ACCOUNTS PLS CHECK THE "PROMOTIONS" TAB IN GMAIL, IF ITS NOT THERE CONTACT US OVER THE CONTACT FORM.
THKS
Freaktab Admin
[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
cons
Comparing with stock is more slow, you can notice that when you install apks.
You can not install apks that are not for android tv. Lets say normal Play Store that i had with the stock rom.
pros
Menu now is more ANDROID TV.
Temperature are lower from stock.
Screen does not freeze.
You can close apps from the background.
Questions...
How can i enter TWRP mode?
If i install magisk is there any possibility i break the rom testing apps and modes?
Thank you Magendanz. I hope the maintaining continuous.
I would like to install nexus on my mecool pro w because I have some freezing while I'm watching IPTV dunno why... It seems that the link of newest rom of nexus that Magendanz posts doesn't let me download... Can anyone please give me the nexus rom link for download? Thanks
Tested in my m8s pro w (lunn is same m8s)
Is the best rom
All working and fast
drm L3
I dont have black screen in molotovtv and netflix phone
Plase can you convert this rom to androidtv
Pleaaaase
Is the best rom
drm L3
Pleaaaase
hello Magendanz. if i make an ota updateι i will lose my unroot ?
also i have one problem with the home button it is not working and i cant close the open apps ,any advice ?
thank you in advance
I am having an issue with my Mecool M8S Pro W rev. 2.3 after trying to flash the Nexus rom on it. It bricked, red led, black screen, reset working, the only thing that worked was shorting the pins on the Nand flash. Now it gets detected by pc everytime I plug the usb into it. But...I can't find any good images to flash on it ( tried more than 15 ). Most of them get stuck at 4% with Usb burn maker or 7% ( [0x32030201]Uboot/Get result/Disk Initial error ). 90% of them aren't bootable with SD card maker, and those who do work, get stuck at like 2-3% on tv at "upgrading..." ( Lunn-NHG47L-20190418.114957.V0213.img , this one is among the few that is accepted by the tvbox on the SD card ). I am running out of ideas on how to get it working. Can anyone help me with a good firmware image ? I contacted Gearbest support in order to ask for a good working image to flash and they said they'll refund me ( which is good ), but nothing about the stock firmware. Maybe I am doing something wrong, since I'm only a beginner, or I just don't have a propper firmware image for this revision.
I've Installed the ROM in a M8S Pro W rev 1.0 and im getting the error (-100) could not connect to Netflix when I try to use Netflix, is there a fix?
Also when you try to send a video to youtube it gives a connection error, but if you manually add the TV using the code provided in the app it works as long as you have youtube app open
