[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Originally posted by kolinsb View PostMaybe you need to ask for newer firmwarei sold one M8S pro w yesterday, and buyer told me that he has problem with ethernet port too. I didnt tested it, and i didnt knew it is not ok
the most of users usualy using only wifi.
i own a m8s pro w and i had an issue after flashing this rom.
the first boot went ok but after a subsequent restart, i get the screen of the green droid with a red circle and X in it.
the same happens when i try entering recovery.
how do i get my box back to default since recovery does not work as well?
I have a mecool m8s pro w that I received yesterday.
I followed the instructions in post nr 1. I copied the zip onto a usbstick and ran the update app and performed a local upgrade. I ticked both the checkboxes to erase cache and media if I remember correct. The new rom was installed and I watched the progressbar go to 100%, it felt correct. Then the screen went black. I waited for about 3 minutes in case it was booting up but nothing happend. I removed the power cord and inserted it again and nothing happens. The mecool led turns blue but nothing appears on the screen.
What happend? Is there a way to repair it? I created a bootable sd card with burn card but i couldnt find a reset button to put the device in recovery mode. I opende yhe chassi and found only solder points where the reset button should be. Is there a way for my the recover from this failure?
Best regards,
FredrikMK809III RK3188-T AP6210 running Neomode 3.1
Hi again,
I have red som more on this forum and I just get more confused about the different versions of the m8s pro/plus.
I have av m8s pro w (no Android tv and no remote).
Is there a custom rom so that I can get Andorid TV on my unit?
Can I flash it to plus first and from there flash/add Android tv?
Can someone please point me to a forum thread if this is possible?
Best regards,
Best regards,
Fredrik
WARNING: Newer M8S PRO W units may have hardware revisions that make them incompatible with earlier firmware releases. My advice would be to only flash a custom ROM that's based on a known-good OEM firmware release for your box. That said, this latest release is also compatible with the new M8S PRO PLUS units configured with
Originally posted by soldiaz View PostIt works? My box did Not boot...we talking bout same rom?MK809III RK3188-T AP6210 running Neomode 3.1
There are currently 3762 users online. 3 members and 3759 guests.
