what could it be?
[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Same problem.
Netflix screwed up something on his side. Nvidia and xiaomi only work with tvbox for this time. The problem is from about 24h. You have to wait until it repairs or until someone comes up with how to solve it.
Children cry that there are no cartoons. The mother-in-law does not live without tv shows. I had to go stealing content from torrents and install kodi ;-)
Originally posted by hawkdown77 View Postanyone facing troubles with netflix? since yesterday i got an error tvq-pb-103 (2.10.0)
what could it be?
Originally posted by na5eer View Post
I have exactly the same problem at first thought the Netflix update had somehow deleted my widevine L1 key or something, kind of glad that im not alone in having this problem!
Originally posted by chmurson View Post
This problem is global and affects all boxes except xiaomi and nvidia. I found some problem reports on Reddit and a few local groups (Turkish, Polish, etc.). Netflix has deep in the ass of users of chinese boxes and I do not expect to quickly solve the problem
Originally posted by chmurson View PostMecool users are not the same customer target. Netflix probably does not even test changes in its environment on other devices other than xiaomi/nvidia.
Originally posted by chmurson View PostReturning to the topic related to rom.
Has anyone tested the ethernet port? Although the system can see it, the port does not work (no detect cable connect when i pluged to switch).
Sent from my POCOPHONE F1 using Tapatalk
After turning off wlan (via android switch off) there are no changes.
Eth0 interface does not wake (no LED indicating communication on the switch).
Manually adding IP to the interface with console do not solve problem.
Does anyone having the exact same device:
M8S Pro W and rom from this thread can test if ethernet works?
I initially had issues with my M8s Pro L nexus rom (LB) , but issue resolved once i bought a good quality Ethernet cable. I did not need to switch wifi.
The cables are 100% functional, the switches also (tested in other devices)
I think that it must be a problem in rom in this particular M8S Pro W model
I tested on 3 different cables (cross, straight) and 2 different switches (100mbps, 1gbps)
There are currently 2873 users online. 0 members and 2873 guests.
