[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Originally posted by chmurson View Post
Originally posted by Novato View Post
What is your device? Is the model coming to Andoid TV and has 2.4G in the name? If so, just have a solution, go back alduns post will read. I think it starts on page 16, the procedure involves installing the Mecool M8S Plus W firmware by launching the Flash tool on the PC.
The motherboard has a sticker: M8S PRO W 2G 16G DDR3 DV and BB-ROC180903PW 2G+16G
The firmware was originally somehow from July or August 2018..
A similar problem I see in # 310 and #311 has been resolved. Tomorrow I will try to do it because today is already 2:30 AM and at 6AM I have to go to workLast edited by chmurson; 28 November 2018, 02:26.
On the cover of the device is inscription: M8S Pro W
Good luck bro, it can not get any worse. I have a Mecool M8S Pro (S912) several months with this same problem. I even gave up on him for now, I'll have to buy a 30-inch Ugreen 2.0 cable to try to retrieve this box.
Originally posted by krawo View PostHi, I have bought Mecool M8S PRO W from geekbuying, without preinstalled android tv and without voice control. How can I make sure that my version of this device is good for installing this ROM and won't brick it?
Now i have sucesfull unbirck via M8S_PLUS_W 20180622.img and my device is now M8S PLUS W !!! ;(
But This rom has awful launcher (it does not look like an androidtv - nexus).
When i tru install M8S_PRO_W-ota-20171017.112143.V0619.zip
i have this error (wrong device!!!)
When i try install OTA update M8S_PRO_W-ota-20180126.191102.V0928.zip i have this error:
My unbrick procedure (m8s pro w) - black screen, only red led.
We need male-male usb cable, I was made from two generally available microusb cables.
Just cut them in half and connect wires one-to-one (red-red, black-black, green-green, blue-blue)
1. Run the USB_Burning_Tool program
2. Connect the power supply to box and USB cable to port closer to the power plug (only this port working as modem)
3. The program should detect the device, and You can proceed to upload img.
The matching firmware is M8S_PLUS_W 20180622.img, others stopped at 7% with an error
4. After uploading the firmware, resetting the device, the first start takes a few minutes.
My M8S PRO W has changed to PLUS W ;( and install some wird software (but finally work!!!!)
5, To fix this you need to follow the guide:
https://forum.freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905/others-ac/firmware-roms-tools-bj/752605-rom-oem-mecool-m8s- plus-in-android-tv-to-videostrong
After flashed, the first start takes a few minutes. TADA!
We enjoy pure androidtv (not some Chinese junk soft)
hi Guest is that possible if i flash it to mecool m8s plus DVB ?
Specs:
● CPU: Amlogic S905D Quad Core 64-bit Cortex-A53
● GPU: Penta Mali-450
● OS: Android 7.1
● Storage: 1GB DDR3 RAM + 8GB ROM
● 2.4G WiFi
● Support 4K, H.265
regardsLast edited by ghaliharisma; 29 November 2018, 16:26.
Originally posted by ghaliharisma View Posthi Guest is that possible if i flash it to mecool m8s plus DVB ?
Specs:
● OS: Android 7.1
● 2.4G WiFi
● Support 4K, H.265
regards
There are currently 1754 users online. 0 members and 1754 guests.
