[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Thanks, IE button was the trick, succesfully unbricked. It didn't work from USB stick though, got that same error saying this is not for the plus-model.
But from SD card it was successful and worked perfect.
Now I have Netflix playing HD and it seems to work fine.
But I have quite a lot of trouble with Kodi and DVBViewer client. Playback is horribly jerky. Has anybody found any solution to that?
Originally posted by HD. View PostNow I have Netflix playing HD and it seems to work fine.
Souvent, les lecteurs (ou addons) vidéos/IPTV , lorsqu'il existe plusieurs flux vidéos choisissent soit la plus basse qualité, soit une qualité intermédiaire pour limiter la bande passante utilisée sur ta connexion.
However, these same applications often have an option to automatically force the video stream to play at its best resolution.
Cependant, ces mêmes applications ont souvent une option qui permet de forcer automatiquement la lecture du flux vidéo dans sa meilleure résolution.
If the application does not offer this option, you can also use the direct link of the video stream in the resolution of your choice.
Si l'application ne propose pas cette option, tu peux également utiliser le lien direct du flux vidéo dans lé résolution de ton choix.
Originally posted by sappy View PostLatest Stock version is: M8S_PRO_W-ota-20180802.182556.V0213
And YES - first step is only to UNBRICK your Box - this ROM is not for this TV Box - only for unbricking...
Next step is to flash some of Stock ROMs through Local update - and I give you the link for latest at the end of my post - 328.... - and do not forget to put recovery.img with this zip on SD card or USB stick - and make a Local update....
Originally posted by sappy View PostHi.., schizzo...
You have to unbrick the box again..., all procedure - again..., I do not have any other suggestion...
This thread is pure evil.
I think I just broke my device (M8S Pro W). Only red dot looking at me from its forehead. Never got to the point where USB Burning Tool actually 'sees' the device. Bridged those reset points and nothing happened. Should there be something like red diode blinking during reset or something?
Any advises/suggestions guys? I'm out of ideas.
Edit: Found the guy on YT who does something like bridging pins (I guess it's memory). Is this something worth tryin'?
Edit2: I'm gonna be grey-haired in a minute... Red diode turns itself blue after some time (about 2 minutes). Screen is black. What is going on?
FINAL EDIT: Problem SOLVED. You don't need to answer anymore. Best regards.Last edited by Mariano77; 06 November 2018, 13:36.
Originally posted by Marcelo Filgueira View Post
Here is the link, .img and .zip. i used to solve the problem on M8S PRO+ with S905W.
https://drive.google.com/open?id=1ZK...HFelPp6S74nW5R
hello Helio, do you have the M8S PRO + with S905W? if you have, I found the correct version for this box, if you want I'll send the link.Last edited by Helio Matias; 07 November 2018, 14:24.
i updated ota file with usb but now not working.
i tried usb burning tool with reset pins.
starts to download but at %4 i got this error :
[0x30201004]UBOOT/Disk initialize/Send command/Error resul
what should i do?
edit:
thanks i could install post 253 firmware now workingLast edited by mature; 16 November 2018, 19:39.
There are currently 2025 users online. 0 members and 2025 guests.
