[ROM] Mecool M8S PRO W TVStock Nexus ROM (Android TV 7.1)
Do you mean the OEM firmware of the M8S Plus W? If so, it is bad. And with only 1GB of RAM in this box, everything will crash, so you have to have a lot of patience and think well which ones apps to use. For example, using the browser is stressful. I was using the VIA browser before doing the upgrade.
Hi trebor Should I give up the tutorial? I really wanted to be able to share with the people who have this device.
Originally posted by Novato View PostDo you mean the OEM firmware of the M8S Plus W? If so, it is bad. And with only 1GB of RAM in this box, everything will crash, so you have to have a lot of patience and think well which ones apps to use. For example, using the browser is stressful. I was using the VIA browser before doing the upgrade.
Enviado de meu MI 5 usando o Tapatalk
Hello all. I have a Mecool M8S Pro+ Android TV OS TV Box with voice remote control. It is working good enough for my fathers daily use. But there is one problem with stock firmware. Exo player does not play 4K HLS streams,.
This is the device:
I usualy had success with this modified firmware but in title it says it is for M8S Pro W and not M8S Pro+. Specifications looks the same. Is it possible it will still work?
My current firmware is "7.1.2/api25/M8S PRO PLUS-userdebug 7.1.2 NHG47L 20180827.121904.V0213" and I am affraid if I flash it, that I will not be able to go back, since I can't find this stock firmware anywhere. Also I do not want to lose any Widewine licenses if any.
What do you think? Would it work on M8S Pro+ S905W (2GB RAM /16GB ROM)?
Thank you a lot for information and reply.
Originally posted by THJ View PostHello all. I have a Mecool M8S Pro+ Android TV OS TV Box with voice remote control. It is working good enough for my fathers daily use. But there is one problem with stock firmware. Exo player does not play 4K HLS streams,.
This is the device:
Probably, installing this firmware will result in 'hardbrick' on your device. My suggestion is that you try to make software changes and use players like MX Player or VLC Player. Change the SW, HW, and HW + settings.
Originally posted by Novato View PostIf it is the model that does not come Android TV and Air Mouse 2.4Ghz probably yes.
Originally posted by Novato View PostYes! Both say that it has Android TV OS support, it will probably come from the Android TV OS factory or will be available in the Box Update App.
Originally posted by Novato View PostThere is and for the price difference, it would be interesting to get the Air Mouse, or you can choose to pick up the model with gyro in the Alie. Search for Air Mouse G10s.
Originally posted by Casterina View PostSo the box will work with the ROM in this thread? As I read few pages back that people have bricked their box, black screen etc.
I have a spare air mouse so I will just go for the cheaper option without it.
Hi, after tying flash nexus rom I bricked my device (black screen)
Attempts to load img through the USB_Buring_Tool are unsuccessful (error of 7% progress)
I tried to flash with a tight reset pins, or without ... Unsuccessfully - there was always an error in the same place.
Some ideas how to fix it??
Code:[01:19:35 667][HUB2-2][Inf]--Start burning... [01:19:35 720][HUB2-2][Inf]--------------ERASE BOOTLOADER------------ [01:19:35 720][HUB2-2][Inf]--0-7-0-16 [01:19:35 720][HUB2-2][Inf]--Identify status success [01:19:35 720][HUB2-2][Inf]-- low_power [01:19:35 720][HUB2-2][Inf]--Low power command success [01:19:35 720][HUB2-2][Inf]--Read low power success [01:19:35 720][HUB2-2][Inf]--bootloader_is_old [01:19:35 720][HUB2-2][Inf]--Bootloader command success [01:19:35 736][HUB2-2][Err]--failed: bootloader is new [01:19:35 736][HUB2-2][Inf]--Bootloader is new [01:19:35 736][HUB2-2][Inf]-------------Download DDR.USB----------- [01:19:35 736][HUB2-2][Inf]--Close device handle 0x0000098c [01:19:35 805][HUB2-2][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&c0f0d73&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000003d8 [01:19:35 868][HUB2-2][Inf]--0-7-0-16 [01:19:35 868][HUB2-2][Inf]--No need download [01:19:35 868][HUB2-2][Inf]-------------Download UBOOT.USB----------- [01:19:35 868][HUB2-2][Inf]--0-7-0-16 [01:19:35 868][HUB2-2][Inf]--No need download [01:19:35 868][HUB2-2][Inf]-- low_power [01:19:35 868][HUB2-2][Inf]--Send command success [01:19:35 868][HUB2-2][Inf]--Read command status success [01:19:35 868][HUB2-2][Inf]-------------Download meson1.dtb----------- [01:19:35 868][HUB2-2][Inf]--0-7-0-16 [01:19:35 868][HUB2-2][Inf]-- download mem dtb normal 88064 [01:19:35 868][HUB2-2][Inf]--Send download command success [01:19:35 890][HUB2-2][Inf]--Read command status success [01:19:35 905][HUB2-2][Inf]--Transfer complete [01:19:35 905][HUB2-2][Inf]--Send download get_status command succeed [01:19:35 905][HUB2-2][Inf]--get_status success [01:19:36 426][HUB2-2][Inf]-------------ERASE FLASH----------- [01:19:36 426][HUB2-2][Inf]--disk_initial 1 [01:19:36 426][HUB2-2][Inf]--Send command success [01:19:36 644][HUB2-2][Err]--failed:[01:19:36 644][HUB2-2][Err]--Check command return failed [01:19:36 659][HUB2-2][Err]--[0x30201004]UBOOT/Disk initialize/Send command/Error result
There are currently 1066 users online. 0 members and 1066 guests.
