Just follow the same download link in post #1.
Ugoos UT1 Riley/Finless ROM v1.0 [Feedback]
The upload is done for v1.0a.
Just follow the same download link in post #1.Randy
Thanks lots rrileypm for this Rom!! It made my UT1 so much better!!
Can anyone help with getting xbmc to work right on it? I have installed the official version from http://xbmc.org/download and have set it all up but I can get it to pick up any off the hardware acceleration and sound setting, I can play SD files but no HD, they lag and sound doesn't work.
Any help will be appreciated!Last edited by willnixo; 09-01-2013, 00:30.
Originally posted by willnixo View PostThanks lots rrileypm for this Rom!! It made my UT1 so much better!!
Upgraded to the new rom - Many thanks. Tried it on my 720p/1080i TV and it does not display any signal and the screen is balck. I moved to another TV which is 1080p it works fine. Also the USB ports no longer recognise my hard drives? I would really like to get it working on my older 720p/1080i TV and that is the main TV we use. Your help is much appreciated.
Hello there,
Just compiled 720p and 1080p kernel for UT1 from phjanderson's source repository.
Feature:
1. vsync fixed
2. support both 720p and 1080p
3. fix mac address
4. fix ir remote for both UT1 and CS918(need new kl file)
5. overclock(cpu1800, ddr720, gpu600)
Download link:
kernel https://www.dropbox.com/s/zo77tr0qo1...80p_kernel.zip
kl file https://www.dropbox.com/s/ddg9xwi6v4...x-remotectl.klLast edited by ibazzi; 09-03-2013, 06:19.
Thanks for posting. If anyone tries it, give us a report.
RandyRandy
Feature:
1. vsync fixed
3. fix mac address
Download link:
Please, could you explain how to use this kernel? I am so newbie that I do not know what to do with it. is it for to change the Randy's ROM kernel? Or what?
Thanks in advance for your clarifications...
All you need to do is replace this kernel with mine in the RileyROM folder. Open the flash tool and uncheck everything except kernel.img and flash without erasing IDB.
RandyRandy
It will flash ok as long as it is smaller.
He must have removed some unnecessary code
RandyRandy
One thing to consider is that when dumping you shouldn't be running any apps. Turn Wifi off so no files will be changing during the process. You will get a cleaner dump that way.
RandyRandy
There are currently 1601 users online. 4 members and 1597 guests.
