Amlogic Next8P12 (NXM805MC) Modified Recovery - Stock Rom - Root & Gapps
    Originally posted by roadkill View Post
    pm shaun he might know wats wrong somthing might b corupted not sure
    Thanks. I'll give that a shot. I really want to get a new rom on this (preferably with gapps.) It runs like crap with the base rom.
      q
      do u know if u have the rock chip or the amloic ?
        I put Modified Stock 3e Recovery on SD card.
        I booted from SD card.
        Rooted first before I did anything else.
        If yours doesn't work maybe you have the wrong version tablet-
        Download CPU-Z app. and check it. It should look something like this-
        Maybe yours is not Amlogic ?
        I'm sure I'm screwing up somewhere on this, but everytime I try to flash the rom it says that the rom is not signed.
        This happens with every package and the gapps.
        Do I have to root the stupid thing first? I didn't think I had to since it had root in one of the packages. Any ideas?
          CPU-Z tags it as the Amlogic.
            q
            thats good sighn
              http://www.freaktab.com/attachment.p...1&d=1389031533
              Mine matches up almost perfectly (except for available memory of course).
                u got supoer user instaled right?
                  Maybe that is it. I didn't think you needed superuser until rooting. (or it would already be in the rooted rom). I have to find a copy to sideload real quick since this stupid think didn't ship with any appstore nor is it on Amazon.
                    Re: Amlogic Next8P12 (NXM805MC) Modified Recovery - Stock Rom - Root & Gapps
                    Superuser / supersu /etc... is optional (and highly recommended) but necessary and can be installed later...
                    something is wrong because Tajlund can't flash anything...
                    Sent from my SPH-L710 using Tapatalk
                    Freaktab Rom Developer
                      Yep, just tried with SU installed and it's still saying unsigned and installation aborted.
                        q
                        defiantly somthing wrong ? mabe somthing with the modfied recovery ?
                          Ok I think my problem is even bigger. In the initial instructions shaun says to unpack the file and put it on the card. Well, when I try it that way recovery can't even see it. When I try it zipped (like I have on most rom flashes) it sees it. When I select the rom it says that it is unpacking and then installing. At that point it says that the rom isn't signed and aborts installation.
                          Maybe this info will help pinpoint what's going wrong.
                            q
                            well shaun can figure it out
                              This is what I suspected... you're doing it wrong.
                              The modified recovery doesn't get flashed, it gets installed manually, then it has to be used to flash the other packages.
                              To install the modified recovery, you unzip it, remove the uImage_recovery file and place the uImage_recovery file on the top level of your external sd card. Then, when you insert the external sd card and boot with power and volume- held down, the amlogic chip will automatically use the recovery on the external sd card instead of the stock internal recovery.
                              Then you'll be flash the kyser_root.zip or the stock rom .zip normally.
                              The kyser_root is for root only.
                              The rom is non-root if you need to return to stock for some reason.
                              ShaunMT
                                ShaunMT
                                I figured I was screwing something up. Seemed to run perfectly following the instructions. Got Gapps and have root.
                                Hope it's more stable with less bloat on it. Now if I can just get the SD card slot fixed I'll be in the good.
                                Thanks Shaun, you're a lifesaver.
