My goal on this one was making the rom the smother/faster that i cant compared with the stock, and i think i did it... i let you guys judge that!
Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
YOU NEED TO BE IN SCV1 FIRST BEFORE TRYING TO FLAH SCV2!
THIS ROM IS ONLY FOR THE LQ VERSION, SEE THE STICKER UNDER THE BOX.
Changelog V2:
- Disabled Navigation bar, not needed anyway....
- Fixed Gray bar in Netflix videos.
- Fixed "Navigation" bar not hiding in Google Play Movies.
- Some changes to the audio.
- Updated TWRP to 3.2.1-0
Changelog V1:
- Based on latest ota 20171216
- Cleaned lots of stuff...
- Lot smother... and faster, not a lag fest like the stock one!
- Added TWRP
- It should have a better cpu usage/ram.
- Cpu temp should also be better.
- Fixed chromecast that was always crashing in the stock rom.
- Unrooted ( Yes now you can install magisk or whatever you use to root, use the included "Update" app to flash it! )
- General optimization and how the ram is used, should better now.
- Permissions fixed.
- Double press on Home button bring the APP Switch Menu ( Or App kill menu )
- Status bar Auto hide
- Navigation bar auto hide ( Enable the nav bar in the settings )
- Working ATV google remote control!
- Netflix FHD Android TV app, install from Playstore
- Netflix 5.1 Sound ( Experimental )
- 4k Youtube support!
- Updated DTV App to the latest one.
- FTMC Build 31.
- Some audio mods ( Experimental )
- Settings menus working ( VPN can be added... )
- Added lots of Kl's
- initd.d support.
- Added google cast, ( Will only work with youtube... )
- Xbox360 wireless Gamepad, original and Chinese clones?! ( well it works with my clone adapter... )
- PS3/PS4 gamepad support(only with cable...)
- Added Dragonrise USB HID game controllers.
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.5.5 -> Up, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices), Kodi 17 its a it and miss this days!
- Optimized some animation stuff!
- And other little stuff...
- And of course all the other ATV mambo jambo...
Bugs V1:
- If you have any Wifi problems like slow net etc, disable Bluetooth ( is enabled by default ) if you dont need it... it will make the wifi work a lot better!
- I bet you guys/girls tell me if they are more
Want to buy me a beer?
Downloads:
- DOWNLOAD HERE SCV1 AND SCV2 ATV ROMs
- MD5 SCV1 IMG: 46F0421392847E3768646CE70E115912
- MD5 SCV2 OTA: B7B2F68E7AE50F8B1752A98B06095ED9
Install instructions:
- DON'T UNPACK THE ZIP
- Use the included "Update" app that is on stock rom, CHOOSE "Local" on the app.
- Or just boot to recovery and flash it....
- THIS WILL DELETE ALL YOUR DATA...
1º BOOT TAKES AROUND 5 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
