Thank you!
[ROM] Mecool M8S PRO L SCV2 ATV - Android 7.1.2 ( Android Tv Version )
Look at the pics in this link (post 183) to see where to short the spot to get into the flash mode (first pic). To get into the flash mode, you have to short the two narrow holes, then connect the male to male USB cable. Turn up the volume on your computer so you can HEAR the box connect to your computer. Also, you have to make sure you are using the correct USB port, one of them is the OTG port, and that is the one you have to use. If it still does not recognize, your box, try a different USB port on your computer. My computer does not supply enough power through the USB port, so I use an external POWERED USB hub connected to my computer.
http://freaktab.com/forum/tv-player-...-tv-7-1/page13
so i can install SCV1-ATV-A7.1.2-M8S_PRO_L.zip and after SCV1-ATV-A7.1.2-M8S_PRO_L.zip and it is ok
thanks
You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
hello, help me,
i cannot install neither firefox, neither skype ?? how i do ?
thanks.
EDIT : soluce : i put this one :
http://freaktab.com/forum/tv-player-...7-1#post686034
Télécharger:- Nano Variante: PAQUET BURN (924MB fichier IMG), mise à jour OTA (476MB fichier ZIP)
- Stock Variante: PAQUET BURN (fichier IMG 1,42 Go), mise à jour OTA (807MB fichier ZIP) <======== this one
- Paquet de brûlure Flash avec Amlogic USB outil de gravure v2.0.8 ou BootcardMaker v2.0.0.2
I got my M8S Pro L last week, everything works fine with the original firmware.
But I can not enable wifi after I flashed this rom.
Everything else works great with a lan cable.
Is it because I got a different wifi chip?
And how can I add a wifi driver into this rom?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by alloy1124 View PostI got my M8S Pro L last week, everything works fine with the original firmware.
Hi on Other rom i have this bug when i try to play fullhd iptv with perfect player and internal decoder https://ibb.co/kMi7jn
Fixed on this rom ?
Sorry for my english.
Originally posted by CHANG KIHO View PostI use voice(Mic) model box like below
but can't use voice input. how can i do?
Thanks Superceleron for your effort all the time...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
The Bluetooth Voice Remote from that link is a combo IR and Bluetooth. Make sure you pair the Bluetooth portion of your remote.Last edited by CHANG KIHO; 06 April 2018, 10:50.
Bluetooth Voice Remote is paired. IR fuction is working but voice input is not working.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Will this version work for the Vorke Z1?Please take the time visit my fundraising page for an accessible wheelchair van.
Click here to support my wheelchair accessible van fundraiser.
https://i.imgur.com/pldcvD6.jpg?1https://i.imgur.com/PaM4GAy.png?1
Have you verified that you are indeed using the Bluetooth commands vs, IR?? Cover the sending/receiving port on your remote with your hand, or point the remote in the opposite direction, and try different commands. Voice input works on my both my "L" boxes......
BUT on Bluetooth mode, all functions are working except voice input.
on other firmwares (original ROM(20180205.111652.V0928) & Magendanz ROM (20180310)), voice input is OK.
There are currently 1620 users online. 5 members and 1615 guests.
