[ROM] Mecool M8S PRO L SCV2 ATV - Android 7.1.2 ( Android Tv Version )
Originally posted by mike_la View Post
Originally posted by martybg View PostMan I know that it wont work what would work ? You said something about phone what do I have to do?
On a side note I think I might have an bigger issue. When I tried to install the update. I think this is what is causing my Widevine issue as well. Looks like my M8S Pro L thinks it is a different box. you can see it from my TWRP error. Package fingerprint is not matching up. This is probably cause by me and my disregard for safety in flashing. I'll do more research and get back if I resolve this issue.
This is one of my favorite remotes......... But it does not have a mic for Voice.
http://freaktab.com/forum/tv-player-...-bt4-1-100mbps marty-bg start from post 6 and see if you can pair your phone to your box when you set up your google account.you should then be able to skip the part in set up about pairing your remote.if all goes well you will be able to use your phone as your remote via the app.
Hey Martybg have you tried to get into recovery using the menu button on the remote? Instruction (3) up above. Its a hit or miss. Sometimes it goes directly into recovery or it will just start the box. My best practice was just keep hitting the menu button repeatedly until it gets into recovery. Once you are in follow the steps. If not you may need to open the box and do a pin short.
Originally posted by supermal View Postmy box has ddr3 LB this one has ddr3 LQ.and there are others with different letters at the end.no wonder people are confused about what box they actually have.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
All 3 of my "L" boxes have LQ.Last edited by supermal; 29 April 2018, 12:24.
Originally posted by superceleron View PostHi there guys and girls, one more rom/fw for you all!
My goal on this one was making the rom the smother/faster that i cant compared with the stock, and i think i did it... i let you guys judge that!
Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
YOU NEED TO BE IN SCV1 FIRST BEFORE TRYING TO FLAH SCV2!
Changelog V2:- Disabled Navigation bar, not needed anyway....
- Fixed Gray bar in Netflix videos.
- Fixed "Navigation" bar not hiding in Google Play Movies.
- Some changes to the audio.
- Updated TWRP to 3.2.1-0
Changelog V1:- Based on latest ota 20171216
- Cleaned lots of stuff...
- Lot smother... and faster, not a lag fest like the stock one!
- Added TWRP
- It should have a better cpu usage/ram.
- Cpu temp should also be better.
- Fixed chromecast that was always crashing in the stock rom.
- Unrooted ( Yes now you can install magisk or whatever you use to root, use the included "Update" app to flash it! )
- General optimization and how the ram is used, should better now.
- Permissions fixed.
- Double press on Home button bring the APP Switch Menu ( Or App kill menu )
- Status bar Auto hide
- Navigation bar auto hide ( Enable the nav bar in the settings )
- Working ATV google remote control!
- Netflix FHD Android TV app, install from Playstore
- Netflix 5.1 Sound ( Experimental )
- 4k Youtube support!
- Updated DTV App to the latest one.
- FTMC Build 31.
- Some audio mods ( Experimental )
- Settings menus working ( VPN can be added... )
- Added lots of Kl's
- initd.d support.
- Added google cast, ( Will only work with youtube... )
- Xbox360 wireless Gamepad, original and Chinese clones?! ( well it works with my clone adapter... )
- PS3/PS4 gamepad support(only with cable...)
- Added Dragonrise USB HID game controllers.
- Fixed auto frame switch in kodi. It only works on FTMC(included) SPMC 16.5.5 -> Up, on kodi 16.1 doesn't work because is to old(misses a lot of fixes for the new S9xx devices), Kodi 17 its a it and miss this days!
- Optimized some animation stuff!
- And other little stuff...
- And of course all the other ATV mambo jambo...
Bugs V1:- If you have any Wifi problems like slow net etc, disable Bluetooth ( is enabled by default ) if you dont need it... it will make the wifi work a lot better!
- I bet you guys/girls tell me if they are more
Want to buy me a beer?
Download SCV1:- DOWNLOAD HERE SCV1 ATV ROM
- MD5: 46F0421392847E3768646CE70E115912
- DOWNLOAD HERE SCV2 ATV OTA
- MD5: B7B2F68E7AE50F8B1752A98B06095ED9
Install instructions:- DON'T UNPACK THE ZIP
- Use the included "Update" app that is on stock rom, CHOOSE "Local" on the app.
- Or just boot to recovery and flash it....
- THIS WILL DELETE ALL YOUR DATA...
Where to buy:
1ยบ BOOT TAKES AROUND 5 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
thanks!
I installed NEXUS ROM but wifi and bluetooth did not work so I tried to load the original ROM again but I tried to get the original version of the ROM but not the voice control TV. If you have ir remote ROM, please link.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 6089 users online. 2 members and 6087 guests.
