[ROM] Mecool M8S PRO L SCV2 ATV - Android 7.1.2 ( Android Tv Version )
Androidboxlover
Yes it is. Custom rom for Mecool M8S Pro +
Android tv 7.1 : http://freaktab.com/forum/tv-player-...android-tv-7-1
Android 7.1 : http://freaktab.com/forum/tv-player-...ms-android-7-1
Originally posted by rlghplay View PostI made my own backup rom share.
TWRP BACKUP ROM LB Version
M8S_PRO_L-userdebug_7.1.2_NHG47L_20180417.150752.V0213
Originally posted by rockinhc View Post
I used this and my screen is stuck scanning for remote. I can't seem to bypass the screen using the suggested button combo or when using a usb keyboard mouse. https://scontent-sjc3-1.xx.fbcdn.net...57&oe=5BBA81E4MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by demasiado View PostWhat is the DPI setting for this firmware?
Magendanz's ROM is using 240 dpi and RaiPlay crashes at start,
but if lcd.density is modified in build.prop to 320 dpi
it works perfectly...
Thanks in advance.Last edited by natman; 17 June 2018, 13:47.
Originally posted by natman View PostI've installed an ssh server app and I've found build.prop file under system directory. I've edited it and now ray play for atv works well!!!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi Guys,
before i do flash just want to confirm steps.
I have new Pro L box - would like install this rom.
So steps to install:
Download SCV1 - copy zip to SD card and then Install via local update app
after sucessfull update
Download SCV2 OTA - copy zip to SD card and then Install via local update app
This way will be TWRP and all installed no additional steps needed? as the 1st page steps are very "simple/short" written
Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
Can someone confirm update steps also?
thanksAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
There are currently 2705 users online. 0 members and 2705 guests.
