I want 64bit
[ROM] Mecool M8S PRO L SCV2 ATV - Android 7.1.2 ( Android Tv Version )
Originally posted by LoKin View PostWas recently prompted for a new update on my Mecool Pro L android box. Attempted to update it, but it fails every time. I get the following message in the recovery image:
"E: Error in @/cache/recovery/block.map
(status 7 )"
What does this mean? And how do I fix it?
I had the problem when I was going back to a Meccol stock ROM from a custom ROM that I had installed and tried.
First thanks to SuperCeleron and Megandanz for their work on ROMs for these boxes. I have tried them all.
I like the ATV version particularly for the "backdrop" screensaver that shows random pics during idle time and save burning in images on my TVs!
The NOT ATV Roms don't have that screensaver as an option so...… I want the ATV for just that feature. I can learn this fast enough.
Originally posted by Albertron View PostHi. I have installed a New launcher, but I dont know how to put this launcher predeterminated. Anyone knows how to put any launcher predeterminated and the home button go to this New launcher?
On the box
Enable Developer Options and Allow USB Debugging.
On PC
Open command prompt. Use adb over the network and connect to the box by its IP address
adb connection (IP address of M8sL)
Now Run this Command
adb shell pm uninstall -k --user 0 com.google.android.leanbacklauncher
success!
Now your box will use whatever home app you set. Mine did anyway.
Good Luck.
Hey Guys, i'm on a Mecool M8S Pro (LB Version, BT Voice Remote) with Stock-Rom and latest OTA.
While i wasnt watching, my Dog deleted some minor System-Apps (e.g. Hindi Input, guess he doesnt speak that anyway).
Now i found out, my Box doesnt pass the Safety Net-Test. I managed to boot TWRP from SD-Card, and take an Image from all (five) Partitions available. Unfortunatly, i dont have an untouched Stock-Rom.
It looks like this (Post#157) is an Image from an untouched Box:
Originally posted by supermal View Posthttps://mega.nz/#!lJ4GXabD!DDHIu0xLW...evs5dmsP0KTVHs try this link?this is a twrp back up of my mecool m8s pro l box.it is for those who have sticker on the back of the box with LB on the end only!it may not be compatible with boxes with older firmware.use at your own risk.
Does an untouched StockRom pass SafetyNet anyway?
After (hopefully) restoring the Stock-Image, i want to install Magisk, to have a proper Root and to hide it from e.g. Netflix?
Im afraid of turning a medium Issue to a big Mess.... Thanks for clarifing Guys! :-)Last edited by dafunkys912; 01 November 2018, 12:27.
Originally posted by Giannis View PostHi hohenheim
In the following DropBox link is a full twrp backup from the original factory 20180316.115110.V0213 Mecool M8s Pro L (LB) firmware (LB boxes with normal remote). It supports your wifi-BT Broadcom chipset.
You can flash it via twrp recovery (restore). Try it with your own risk.
Tell me if it works.
https://www.dropbox.com/s/4pjfmzzckv...V0213.zip?dl=0
Hi!
I`ve got a Mecool (LB) with the following specs:
Model: M8S PRO L (Android TV 7.1.2)
Version: 7.1.2]
Kernel: 3.14.29
Thu Sep 13 18:28:55 CST 2018
Version # : M8S PRO L-userdebug 7.1.2 NHG47L
20180913.182655.V0213
Which ROM I could download to update it with a better one?
Sorry about my questions, because I am totally dummie about TV Boxes, ok?
There are currently 2872 users online. 0 members and 2872 guests.
