thx
[ROM] Mecool M8S PRO L SCV2 ATV - Android 7.1.2 ( Android Tv Version )
ah great...was choosing this box cos of this FW and updates, but seems like i need to wait for LB mod (which i own)
thxAndroid devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
One more issue the current OS there is probably AndroidTV OS from Mecool, but my local internet TV provider android app - seems to have some check that is checking if its "normal android os" or "android tv os" as result it wont start as it thinks its set top box and this service is changed.
So can i put there "non LB and non Android TV" firmware to avoid this check? or can i just rename somewhere device type - to think its standard mobile or tablet?
EDIT: ok seems like there are 2 types of apps Android and AndroidTV, thats the issue...Last edited by killeriq; 26 June 2018, 17:58.Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Originally posted by natman View PostPeople have reported that using a firmware built for a different version of m8s pro L, makes the new LB box very unstable.
Furthermore, at the moment, there isn't a way to restore the original OEM firmware...
Hi, I updated my M8S Pro L (LB) with the latest 5 Feb firmware and upon rebooting, am presented with the blue "bluetooth is initializing" screen and am unable to successfully pair the remote with the box. What am I doing wrong? I shorted the pins to enable me to do a factory reset but upon rebooting, am still presented with that same screen. I can't seem to get past it. Any help would be much appreciated.
Originally posted by hohenheim View PostHi, I updated my M8S Pro L (LB) with the latest 5 Feb firmware and upon rebooting, am presented with the blue "bluetooth is initializing" screen and am unable to successfully pair the remote with the box. What am I doing wrong? I shorted the pins to enable me to do a factory reset but upon rebooting, am still presented with that same screen. I can't seem to get past it. Any help would be much appreciated.
Originally posted by rockinhc View Post
Bypass this screen by using your phone to connect to the device via bluetooth.
Originally posted by supermal View Post
Latest stock version for LB variant is from march.superceleron rom is not compatible you will lose wi-fi and Bluetooth.probably why you can't pair.you need to go back to stock firmware.
I attempted to do a reset by shorting the pins and selecting the option for factory reset, upon reboot, was presented with the Bluetooth screen once more. Sounds like I might have bricked the box. I also attempted to reset to an earlier firmware but it refused to let me do so saying I can’t go back to an earlier version. Any other thoughts please?
What was the exact error message that was displayed, normally more than 1 line?
Originally posted by Jeffers View Post
I assume by "earlier firmware" you meant the original Mecool ROM, am I correct.
The earlier firmware was a magendanz one from November 2017. The message I got said something along the lines of error unable to revert to an earlier firmware. I took that to mean the Feb 2018 one can’t revert to November 2017. I had that on a USB drive so did an EXT boot. I have done the reboot to factory already and still got the same blue screen. Is there a zip file out there with the factory rom that I should use?
Hopefully someone will reply to your post with a link to the factory zip ROM for your LB version.
Hi hohenheim
In the following DropBox link is a full twrp backup from the original factory 20180316.115110.V0213 Mecool M8s Pro L (LB) firmware (LB boxes with normal remote). It supports your wifi-BT Broadcom chipset.
You can flash it via twrp recovery (restore). Try it with your own risk.
Tell me if it works.
There are currently 2024 users online. 1 members and 2023 guests.
