[ROM] Mecool M8S PRO L SCV2 ATV - Android 7.1.2 ( Android Tv Version )
Originally posted by martybg View PostI cannot get around setup remote my remote is different then the one in the picture I press - and Ok but it cannot detect it?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by supermal View Posthttps://mega.nz/#!lJ4GXabD!DDHIu0xLW...evs5dmsP0KTVHs try this link?this is a twrp back up of my mecool m8s pro l box.it is for those who have sticker on the back of the box with LB on the end only!it may not be compatible with boxes with older firmware.use at your own risk.
How did you activate it with remote or?
It asks me to press - and Ok to activate remote and I cannot get past it also which Rom you had installed before that? And what kind of remote do you have can you post picture?
Originally posted by zuiou View Post
You are my hero, thank you so much! My box is working perfectly again! Wifi AND Bluetooth are working as expected. After restoring the Image I performed a system wipe (factory reset) in twrp. Thank you Thank you Thank you!!
1. Previously I had magendaz SCV2-ATV-A7.1.2-M8S_PRO_L installed.
2. Place the unzipped revovery that supermal provided on your sdcard
3. In your rom boot to recovery via terminal by typing "reboot recovery"
4. in twrp select restore backup
5. select storage (your sdcard)
6. select the folder containing the backup
7. hit restore button
8. after completion do a factory reset in twrp
9. reboot to system.
I have a m8s with voice enabled bluetooth remote
The initial pairing with the remote worked just out of the box
for convinience i connected mouse and keyboard though (remember the remote is hybrid bt + ir) so you will need to point the remote at the device!
Originally posted by alloy1124 View Post
Thank you so much for sharing this backup. I restored boot logo and system from twrp , I got bluetooth worked, but wifi still does not work. somebody know why?
Originally posted by martybg View PostGreat thanks!! Can you tell us how did you install TWRP first without removing the OEM Firmware in order for you to back it up, I have second device coming and I want to install TWRP to backup everything?
EDIT: Also its a RAR file, are you sure that this was backed up using TWRP, did you rename the file or something?
Could it be backed up using the original recovery or no?
mecool/videostrong have changed the wifi chip on the newest supply of the m8spro l.this has caused problems for many of us because they failed to make anybody aware of the change.so custom firmware made for previous version is not compatible with latest version.for example the wifi wont work because the wifi module in the newest boxes is different.so basically depends on what box you have.the newest boxes have sticker on the back that has letter B at the end.i am assuming these are the ones with the new wifi chip.on top of that there is no firmware download for the newest boxes and no support from mecool/videostrong.glad i was able to help.can you tell me the version of twrp that you used?
And I think this chip include wifi and bluetooth in this single chip, so I do not know why bluetooth works and wifi does not work.
I did full wipe, reflash and almost everything I can do. But I still can not get wifi worked.Last edited by alloy1124; 27 April 2018, 06:50.
I used this thread SCV2 ATV before which I got no wifi and no bluetooth, then I used the TWRP to 3.2.1-0 come with the SCV2 to restore your backup. And the Bluetooth works perfect but wifi still does not work. Im 100% sure I have the new wifi chip.
Originally posted by zuiou View Post1. Previously I had magendaz SCV2-ATV-A7.1.2-M8S_PRO_L installed.
There are currently 1584 users online. 1 members and 1583 guests.
