[ROM] Mecool M8S PRO L SCV2 ATV - Android 7.1.2 ( Android Tv Version )
Originally posted by rlghplay View Post
Originally posted by supermal View Post
You have the latest mecool m8s pro l box so you have motherboard with the new wi-fi module.thats why you lost wi-fi and Bluetooth with the Nexus rom.it is not compatible with the new motherboards.i don't think you will be able to revert to pre atv version.not until someone makes a custom rom that is compatible with the new and old rom versions.
https://www.google.gr/amp/s/chinagad...v-box.html/amp
https://www.entertainmentbox.com/latest-mecool-m8s-pro-l-tv-box-firmware-download-android-nougat-7-1-1/amp/
Originally posted by rlghplay View PostI made a big mistake. I can not get back to the original state. If you have someone with the same version as me, I would like to share a backup ROM. Thank you for answer.
Originally posted by superceleron View PostGuys this rom is for the LQ(1º ones that came out) boxes, as you guys know this company's are always changing the HW ... ye is cheap but you will get the consequences of it!
Well i will say than magendanz rom nano stock works(yes with wifi and bluetooth module working) on my unit with lq versión.First Install superceleron rom on my unit i didnt like it and then install magendanz nano stock.I prefer nano stock because i can have all the apps i wanted on playstore.The android tv stock its very limited and yes im aware you can install aptoide to fix the issue but i dont trust aptoide store.This my unit image if anyone want to check it:
Originally posted by rlghplay View Postmaybe 'this device has amlogic / omni_q20x / q20x: 5.1.1 / LYZ28N / chad11141738: userdebug / test-key' This seems to be a problemLast edited by alloy1124; 01 May 2018, 10:07.
Originally posted by rlghplay View PostThank you for answer.
I have tried to install all the existing ROMs.
However, there was no ROM for Wi-Fi and Bluetooth.
However, only the backup ROM shared by supermal worked normally.
it is normally downloaded when OTA update, but stopped with version check error in TWRP.
I have 2 of these one LQ version and one LB version, the LB version is running Android 7.1.2, is Microsoft DRM compatible and has just done an OTA update but the LQ is still stuck on 7.1 and can't connect to the update server so I guess that there are no official updates planned for this variation.
What I would like to know is are they only shipping LB versions now or are there still LQ ones being shipped as I bought both within a week of each other and we would like another one.
They are a great little box but finding out info apart from here is practically impossible
Sent from my Mi A1 using Tapatalk
There are currently 1900 users online. 1 members and 1899 guests.
