[ROM] Mecool M8S PRO L SCV2 ATV - Android 7.1.2 ( Android Tv Version )
Originally posted by turtlegsr View PostUnfortunatly immediatly uninstalled for RAIPLAY app crash, like in Magendanz ROM. For me RAIPLAY app that is a portal to all video library for major italia TV is MANDATORY, please fix this crash and back to test your ROM.
In stock ROM from MECOOL this app works fine.....
Marco
Root the rom and try change the dpi from 240 to 320 in build.prop like the user demasiado said!
Well i'm using the stock 7.1 now (M8S_PRO_L-ota-20171127.165619.V0928)
They changed it to a full ATV launcher and it is 320 density, looks like it is a full ATV rom now, i needed to change to 240 in build.prop to have like more on screen windows and space, not sure why they changed it.
Someone asked for normal android 7.1.2, i just thinking on installing this rom but out of curiosity, why the normal version, is it better somehow?
Cuz looks like ATV has this really bad launcher that is hard to replace and limited google play app repository and also a lot less of details, i don't like it. Probably will look for some workarounds, are there any?
Well interesting theory, but they still will have ATV version of play store and YT, that are just bad.
I had the original stock 0918 rom so i know that there was normal YT app, now it is atv version, just look like broad rom changes to an ATV.
And to be honest it is quite buggy (M8S_PRO_L-ota-20171127.165619.V0928)
# Sorry, wrong thread: please move it to Magendanz's ATV firmware thread, thanks.
I don't know what happened with my previous message (under moderation?),
anyway it looks like auto frequency rate switch does not work correctly with the latest ATV firmware by Magendanz
after setting the permissions /sys/class/display/mode... it does switch but the screen remains black
(audio is ok). The same setup works with the M8S Pro+ with Magendanz's ATV firmware.
Anyone ?
I've had a similar problem to clarkss12 regarding FTMC & SPMC crashing on this rom. I've got my box hooked up to a 4K LG. I believe the problem has something to do with having this box set natively to a resolution of 4K with a refresh rate greater than 30Hz. If i try anything above 30Hz in 4K, both FTMC & SPMC crash the box instantly. However, if i manually set the resolution to 4K 30Hz, both FTMC & SPMC work but the box feels sluggish as hell.
Originally posted by DoubleDip View PostI've had a similar problem to clarkss12 regarding FTMC & SPMC crashing on this rom. I've got my box hooked up to a 4K LG. I believe the problem has something to do with having this box set natively to a resolution of 4K with a refresh rate greater than 30Hz. If i try anything above 30Hz in 4K, both FTMC & SPMC crash the box instantly. However, if i manually set the resolution to 4K 30Hz, both FTMC & SPMC work but the box feels sluggish as hell.
Hello superceleron, could you make a version of your build for the Mecool M8S Pro (not L, not +)? Unfortunately the manufacturer has not released any updates a few months ago, making it difficult to upgrade the Magendanz OEM/ATV build. If you make it, can make the users of this device very happy and with more options of firmwares.
yes i know about it, i will fix it in a next update.
Thanks in advance
Skunz
There are currently 4194 users online. 1 members and 4193 guests.
