Im writeing here to inform about new ways to change resolution on our devices.
There will be no need to use difrent kernels to just swich the res.
You will need just 1 kernel 720p and you can swich the res on the fly to real 1080p
just by using software swich in settings.
This is work in progress, but i was allready able to change the res from 720p to real 1080p with stock 720p
kernel.
So if some one want to try just serch the net for latest N90 tablet firmware and flash it to your tv stick,
then flash just the stock kernel of your device using finless tools.
after flash go to settings>display>mode and change from normal to hd.
the resolution will change.
Further investigation is needed but i think if we work together, it can be acomplished.
please post your findings here
