Change resolution from real 720p to real 1080p on the fly useing just 1 kernel (POC)
probably statusbar take some space.Everything is possible if we work together!
Originally posted by Pluto View PostAlso, as i said before, ScreenInfo app, why does it say that height is 840? Again, im on Nexus 1.2 which i flashed directly with the 1080p Kernel.
You need to delete ro.sf.lcd.density line from build.propEverything is possible if we work together!
Originally posted by neomode View PostHello,
Sorry that you are thinking, this is not the right Forum for you.
The Thread has become attenion.
But our People here want Rom´s and not all Technical Intressted.
Ray
These peoples need to learn some stuff in Android, our boxes or sticks are not iOS you can't give him everything packed in rom's or you can
Ada
Originally posted by Pluto View Postthats 240 pixels, still too much for status bars, they are tiny in my screen anyway.
btw, did am display-size 1920x1080 (also 1080x1920) and am display-density 240, no results.
For me is enough 160 but your choice
Good luck
Let me just say this after messing with a new kernel for the MK908ii.
This setting in build.prop has a HUGE influence and ignore or uses LCD Density setting.
video.use.overlay=
Lewy, this resolution thing is a fake in my opinion. A 1080 kernel and messing with some settings can perform like a 720 kernel and it's a lie! My opinion only.
Want to read more?
Read this last 2 pages.
Antutu can be fooled even when it says 1920x1080!
RockChip is now playing some games etc, based on testing stuff recently.
now i know its a fake.
but i allready implemented the difrent system to my roms.
its a swich to change betwen kernels just with a press of a button from within firmware.Everything is possible if we work together!
I really wish that rom devs adapt this concept in all roms , it will get our tv sticks to a whole
New level and end this resolution thing once and for all.
Currently i do it manually by cwm recovery , but your way is much easier , i really hope that
Your way will get adapted in future.
a simple app wich is fireing up a script with "if" and "else" parameters pointing to 2 other scripts.
one copy build.prop for 720p flash the kernel.img and boot.img then busybox touch file you can use any
i used .720p
if there is no .720p file the 1080p kernel and other files will be flashed if it is there then script remove it and flash 720p files.
easy as thatEverything is possible if we work together!
Re: Change resolution from real 720p to real 1080p on the fly useing just 1 kernel (POC)
Originally posted by lewy20041 View Posta simple app wich is fireing up a script with "if" and "else" parameters pointing to 2 other scripts.
i used .720p
easy as that
This file can be used to dump images too.
Actually I use it a lot to flash from the stick. Is a great tool
yap.
i get the idea when i was working on your cwm compatybility;pEverything is possible if we work together!
dump_image "partition" /folder/file.img
very useful to use with abd from recovery, I take it from androtab, so thanks to fun_ from here.
i used .720p
easy as that
To apply them ? solving this resolution issue is a dream came true for me , thanks.
There are currently 2305 users online. 3 members and 2302 guests.
