Change resolution from real 720p to real 1080p on the fly useing just 1 kernel (POC)
i will for sure after some further testEverything is possible if we work together!
I figured out why the screen is being reported as 1920x1200 instead of 1920x1080. They added space over the kernel resolution to allow for the status bar! If they did not do this then the pixel ratio for the "display area" would not be right and videos would look squished!
A prime example of this is Strauzo's nexus ROM. It is a tablet ROM and does not add screen area for the status bars over the kernel resolution. Thus the video looks squished in the "draw-able area" unless you remove the bars. Seems TV sticks add this "overscan" (if you call it that) to the kernels resolution. This is to keep proper video aspect ratio in the draw-able area.
Lewy, watch out with your am command. It does not work on all frameworks as I have tried that before. Depends how they hacked the framework for resolution.
yhym.
good to know.
thanks bob.
its working on my firmwares:"Everything is possible if we work together!
just use 1080x1920 insted of 1920x1080 in terminal.
the same go to 720p.
have funEverything is possible if we work together!
im glad i could helpEverything is possible if we work together!
Originally posted by Finless View PostIf they did not do this then the pixel ratio for the "display area" would not be right and videos would look squished!
Consisting of 1080p video+120p status bar and the video has a 1:1 pixel mapping.
But when it is sent to HDMI the whole 1200p picture will be squeezed again to fit the TV 1080p
As a result the video image will be squished when displayed on the TV.
But this will not happen when only displaying on a tablet that has a true 1920x1200 resolution
As the image will not have to rescaled by HDMI to fit 1080p. which maintains the 1:1 pixel mapping.
In other words their solution is suitable only for tablets but not for our tv sticks
Which have to send the image to HDMI connection.
Originally posted by lewy20041 View Posti cant tell if its real 1080p or not but its usfull.
only bad info is that lcd density wont change but i will figure it out;p
because if the display area is 1920x1080 and the density didn't change
It means that the true resolution is changed , because this is the only
Way to change the display area if the density doesn't change.
So the resolution switching is true.
an app will be best bet so we can put it into system setting without much probblem:"Everything is possible if we work together!
It looks like i was mistaken , this is clearly a scaled resolution , the texts and icons are all pixilated
Much more than the normal 720p to 1080p up scaling , it is very badly scaled , no comparison with
The true 1080p kernel or even the upscaled 720p kernel.
but anyway good trial lewy , thanks very much for keep trying.
trying wont hurt;pEverything is possible if we work together!
There are currently 2302 users online. 3 members and 2299 guests.
