NEW MK808/MK808B MiniX NEO X5 BASED ROMS (30 AUG 2013)
    If your talking about the first rom it's http://sendfile.su/857811
    Click on the first blue button and then the link underneath it.
    The second rom - http://depositfiles.com/files/cmr04x414 Click on regular download and enter the captcha, use your browser's download manager not a 3rd party one.
    I would recommend you to download the second rom as it's newer and just replace the kernel.
    The Mk808 might have trouble downloading from file hosting websites if you don't use the correct browsers.
    It downloads perfect from a Windows PC.
    Super... Got it working now.... Thanks, can't wait to give 'er a whirl...
      Is possible get clear rooted minix rom for mk808 ?
        Download Minix Neo X5 rom from their website and use this to root.
        Step 1- Install Moborobo [ http://www.moborobo.com/ ] Step 2- Connect NEO X7 with charger, and use the usb cable to connect NEO X7 with your PC, press the power on […]
        Flash a MK808 kernel afterwards or use wendal tools to unpack the rom and replace the kernel.
          UPDATE: (For MK808B, 720p kernel, Single File, Rom is also a bit updated)
          I just want to double check - do you mean that this one is slightly more updated than MK808B_digitopMod_v2.1_WALKMAN.zip ?
          I see the single file one was posted by maximry before digitop's post. Is digitop's the better choice?
          Thank you.
            I see the single file one was posted by maximry before digitop's post. Is digitop's is the better choice?
            Thank you.
            I recommend the MK808B_digitopMod_v2.1_WALKMAN rom as it's the fastest and newest.
            The 'UPDATE' rom is better than the 'http://sendfile.su/857811 (For MK808, 720p kernel)' rom as it only requires one flash without replacing the kernel and some apps are different and it's a bit more stable.
            I'm also experimenting with a CyanogenMod 10 rom for this device and if I get it working, I'll post it here.
              R: NEW MK808/MK808B MiniX NEO X5 BASED ROMS (30 AUG 2013)
              Mo123 can you make an overclock kernel for the Mk808....we are stuck at 2dark4u 1.4(even he promised an overclock kernel 6 months ago).
                Ok, I have downloaded that one. I now have a question about flashing it. I don't have CWM installed. How do I flash the rom without having to install CWM? I cannot load the .zip into RKBatchTool. I can of course extract the .zip, but not sure what to do with the files/folders.
                For now I will flash maximry's since I do know how to flash the .img
                  ¿Install or Not MK808B_digitopMod_v2.1_WALKMAN?
                  Install this ROM ( MK808B_X5_MaximRy_1.0) and it works wonderfully, the better?, or clears worth and to urge the MK808B_digitopMod_v2.1_WALKMAN?
                    I can make an overclock kernel for MK808 but it's not going to be better than 2Dark4U.
                    2Dark4U is already heavy overclocked - kernel_MK808_720_GPU433_1416_RAM1160_VZ
                    You can install Setcpu to overclock the CPU up to 1.6Ghz if you have a heatsink or extra cooling.
                      I've looked at the files again and don't see an easy way to flash it without CWM, sorry.
                        Hm, that is interesting. Well, I am using maximry's ROM now. I would like to try digitop's, though.
                        I did the steps to install CWM (formatted 2GB microsd to FAT32 and copied update.zip to it), but I never got the prompt to install the update. To be honest, I don't believe I've tested the MicroSD card slot on my device, so it could possibly be broken.
                          Try to follow this instructions, it might help.
                            I did have an extra cooling and 2 fans. Alex (2dark4u) was talking about a kernel with cpu at 1.6 gpu at 500 mhz and ram at 1.2.....he did also a benchmark, with 13000 points.
                            I have already set cpu installed but the maximum frequencies is 1.4.
                            I am on finless 1.7 c + 2dark4u 1.4
                            I was just hopping that someone can finish alex work.
                            Inviato dal mio GT-I9000 con Tapatalk 2
                              I hope so too, but i guess thats impossible because alex never released the sources...
                                You can also unzip this rom on a pc and flash it with the regular tools.
                                #Post 15 also contain MK808 kernels that you can use with this rom if you want to flash it to a MK808 instead of MK808B.
                                How can I flash it with "regular tool" ?(i believe you mean bob's tool or RKtool).
