MECOOL-VS-RK3399
MECOOL-VS-RK3399
i made firmware to rk3399 tested with MECOOL-VS-RK3399 i expanded firmware Yundoo_Y8_SCV1-7.1.2 and cloud rk3399_zw_new_all_Sound171121 and tested after i found the right files to cobine and flashed with AndroidTool v2.38 so i got a firmware full rooted network working display with al resolution you can test it this firmware with other rk3399 like CSA96 rk3399 i think MECOOL-VS-RK3399 is the best RK3399 tvbox you can instal SuperSU Pro no boot loop problem.Last edited by wahran; 12 February 2018, 17:42. Reason: if you want to buy rk3399 buy MECOOL-VS-RK3399 easy to use very fast and never get bricked has extern recovery and bootloader button easy to use -
hi
i want to say about this rom made from [ROM] Yundoo Y8 Android 7.1.2 - SCV1 is the only one and cloud rk3399_zw_new_all_Sound171121 . i have all the firmware for all rk3399 some are booting but problem wit no network lan and display resolution limited and no rooted att the end i found the right files to load in MECOOL-VS-RK3399 from Cloudnetgo CR19 and YUNDOO Y8 RK3399 firmare.
here you have some information about some rk3399 wifi chipset and bootloader :
Firefly-RK3399
loader v1.09
Wireless AP6356S
MECOOL-VS-RK3399
loader v1.09
Wireless AP6356S
YUNDOO Y8 RK3399
loader v1.06
Wireless AP6356
Ethernet Realtek RTL8211E
H96 Max RK3399
loader v1.09
Wireless AP6255
CSA96 RK3399
Wireless AP6255
Cloudnetgo CR19
loader v1.09
Wireless AP6255
i owned CSA96 RK3399 i think its but box poor firmware and not support.
MECOOL-VS-RK3399 or iVideostrong VS-RD-RK3399 very stong Development Boards and tested the video and sound in kodi-17.6-Krypton-arm64-v8a its very good and stable.
the firmware is very stable but unistall FMC and you tube and newest one.
test it in your own risk because i have take the risk to get this firmware working att the end ny mecool rk3399 is more expensive then CSA96 RK3399 and H96 Max RK3399.
i forgott to tell you that firmare to H96 Max RK3399. have worked with me.
i answer Boneo i tested to download the archive from google drive and extract to my computer no problem.
Originally posted by yhsno1 View Posthow to flash it
ever flashed a RK Box ??? look here :
http://ugoos.net/blog/rockchip-firmw...flashing-guide
i think it is similar with this Box . Remember , backup your
Rom , Apps & Data before you beginn to flash .
greetings / gefattern
hi, been using rkbatchtool so not used this tool b4 so please be gentle. I finally realised i had to use androidtool v2.39 with windows 10
but not sure where to put the trust file?, the other 8 files i think i have put in the correct places. could someone help plz
wahran
istall Rockchip DriverAssitant first to flah use AndroidTool v2.38 in the menu go to download and then to the firmware you extract download all the files in ordering : loader parametre uboot trust misc ressource kernel boot recovery system low format and then run but never erase flash because you have to stay in bootloader mod :connect usb3 to usb usb2 in the pc hold recovery botton and then plug in power or use reboot apk in android.if you box is rooted
like i said i have made this firmware for
MECOOL-VS-RK3399
loader v1.09
Wireless AP6356S
i shall try to flash the firmware for CSA96 RK3399 Wireless AP6255 if you want and tell you. CSA96 RK3399 has the same firmware as Qintaix Q39 RK3399 here you can found rooted good firmware android 6.0.1 http://qintexworld.com/down/7.html other firmware is not working Ugoos UT5 Pro 32G can break your csa rk3399 box beware.
i tried on r99 & it said Download image OK but when i plugged in power it turns on for a second & then off. thanks for your help anyway wahran, i'll try the Qintax although i may have already a while ago. its only 2 days newer than firmware i've been using from 2017.06.12. Hoping Ethernet don't disappear & resolution doesn't lower on its own with that firmware as well.
hello please someone knows how to activate accessibility options in android 6.0 marshmallow in a tv box with rk3229 and SV6051P wifiChip.
I want to use the buttons remaper application to remap buttons on my remote control but in the accessibility services option it says "there are no accessibility services".
in another rom of android 5 if they appear but in the 6 no longer probe with several rom of android 6 and do not have the option
There are currently 1207 users online. 0 members and 1207 guests.
