MECOOL-VS-RK3399
    About MECOOL-VS-RK3399 : How do you flash firmware because there are lot of img files in wahran archive. Which img is the right one to flash it or something else?
      Open Android Tool
      first unselect all
      replace one by one clicking on the end of each file (this open file dialog box)
      after you replace each file put the mark again
      when you have finish replacing oll files with the new ones click on run
        Android 8.1 is out and ready to download, i found it here:
        http://bbs.videostrong.com/forum.php...extra=page%3D1
        because i cant download from baidu downloaded this one from mega:
        I get failcheck error after flashing rom, but Android bootet correctly.
        For now problem is there are no google apps (Play Services, Play Store, Framework, etc...)
        tried to download and install by myself but without luck getting error : play services has stoped and playstore wont open.
        This Rom comes without root, maybe this causes bad framework and google services installation.
          Hello to all I have th box I tried the 8.1 but have many bugs not rooted not sound ,
          There any progress
          Thank you
            Is there any solution for sound glitch problem with any available firmware for Mecool vs-rk3399?
            • mo123
              mo123 commented
              Editing a comment
              Not that anyone knows of.
              Mecool uses beta firmware full of bugs.
            #36
            To all
            I found an alternative firmware on Mecool VS-RK3399, this is firmware from Magicsee N6 Max, Android 7.1.2
            HDMI work
            USB 2.0 work
            USB 3.0 work
            WiFi work
            Bluetooth work
            LAN work
            MicroCD work
            Remote controller NOT work
            Optical output NOT work
            I did not check the rest...
            https://mega.nz/#!sXIiCYBQ!HUjZM6iia...idb14f5ezAV4tU firmware from 2019.01.15
            https://mega.nz/#!FWIhWYLK!2Ykv90pNq...UWtqKynwBu6LGM firmware from 2018.12.17
            There is also a firmware from 2018.11.23, I did not find live links.
            I installed the firmware from 2019.01.15, it works stably.
              Hi all
              Does anyone resolved this problem?
                Hi guys,
                I have this item. But it s not working stable. I must to flash.
                Is there anyone to help me? Because i dont know how to do that.
                Example Rk3399 not connected with pc.
                PLEASE HELP ME.....
                Sorry for my english
                  Here is the link for you:
                  Password: 8HKMPoYtfEkBDAIlznosTg
                  Install firmware VS-RK3399-HDMI-Android7.1-20171229
                  This firmware works fine for me !!!
                  Do not forget to install a good cooling radiator, otherwise the processor will slow down from overheating !!!
                    Thanks for your interesting.
                    But i need to know how can i install?
                    Can you help me about this?
                      I don’t understand why you bought a board for developers? .. Even if you simply can’t upgrade firmware!
                      Here is the instruction: Update_firmware_ VS-RK3399_EN.docx
                        hello
                        MECOOL-VS-RK3399 is bad tvbox hmdmi connection get broken but for 2 years ago i bought H96 MAX RK3399 very stabil hardware good for kodi and the firmwares are already rooted and working also with firmware boxes like
                        Yundoo Y8 actualy i use AlfawiseH96Max firmware very good
                          Hi wahran and friends,
                          i have this item.
                          Name is videstrong mecool vs rk3399.
                          Original stock firmware is very poor.
                          O need a new firmware.
                          İf you know about New firmwares pls advise me.
                          Advise me new firmware and flashing program.
                          Pls will be very happy.
                          Thanks for goodness.
                            Originally posted by Chekushka View Post
                            To all
                            HDMI work
                            USB 2.0 work
                            USB 3.0 work
                            WiFi work
                            Bluetooth work
                            LAN work
                            MicroCD work
                            Hi friend. How did you flashed?
                            which program did you use?
