but it is cheaper then on the big Stores like : Gear... / Bang.... / 20 bugs cheaper .
look what Bang... ask for a Cloudnetgo with RK3399 / 194Dollar and a CSA96 ONLY
175 Dollar without Shipment , that is expensive .
greetings / gefattern
Model: X99 Type: TV Box GPU: ARM Mali-T860MP4 System: Android 7.1 CPU: RK3399 Core: Dual Core,Quad Core RAM Type: DDR3 Max. Extended Capacity: SD card up to 64GB (not included) |
Decoder Format: 4K VP9,H.264,H.265,HD AVC/VC-1,HD MPEG1/2/4,HD VP6/8 Video format: ASF,AVI,DAT,FLV,ISO,MKV,MPG,TS,VOB,WMV Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,WAV,WMA Photo Format: BMP,GIF,JPEG,PNG,TIFF Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes WIFI: 802.11 a/b/g/n/ac Bluetooth: Bluetooth 4.1 Power Supply: Charge Adapter Interface: DC Power Port,HDMI,Micro SD Card Slot,RJ45,SIM card slot,SPDIF,USB 3.1,USB 3.1 Type-C,USB2.0 Language: English,French,Germany,Italian,Multi-language,Spanish Certificate: CE,FCC,RoHs HDMI Version: 2.0 Other Functions: Others External Subtitle Supported: Yes RJ45 Port Speed: 10/100/1000M |
System Bit: 64Bit |
Power Type: External Power Adapter Mode |
Product weight: 0.3400 kg Package weight: 0.4800 kg Product size (L x W x H): 11.50 x 11.50 x 2.30 cm / 4.53 x 4.53 x 0.91 inches Package size (L x W x H): 20.80 x 14.00 x 6.60 cm / 8.19 x 5.51 x 2.6 inches |
Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x IR Remote, 1 x Power Adapter, 1 x English User Manual |
There are currently 42531 users online. 0 members and 42531 guests.
