X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
    Dont waste your times for this action
    Seems X99 in every way faulty/risky problematic Device!
    NOTE;If you will not use "KODI" than do not upgrade your Device!
    I'm lucky that Gearbest refund me $ 41,- and now Device came to me $ 89,- but in this condition its still "Expensive" and still not to worth to buy it!
    Or if are willing to buy a Device which RK3399 than certainly choice H99 instead X99!!!
    Oley Germany won 2-1 finally last moment Tony Kroos
      Dear Friends
      here is my feedback:
      I have upgraded for the latest firmware and everything went smoothly. i followed the post #123 and had no problems. With this last update i have root and kodi is working. i installed an addon and rebooted the box and everything is there again, including settings.
      If it Helps this is what i have done, thank's to #trebor for all the links
      So here is my steps:
      1 - Download android tool release 2.43, drive assistant 2.45, and x99_20180522 rooted
      2 - install de drive assistant 2.45
      3 - Open android tool release 2.43 and upload the firmware and wait it to load.
      4 - take a usb to ubs type C from my smartphone charger
      5 - connect the cable to my laptop on 3.0 usb port
      6 - with the box disconnected from power the only cable plugged in is HDMI
      7 - Press the reset button near the usb type C port and keep it pressed
      8 - Connect the usb type C cable to the box and then the power cable.
      9 - a message in the android tool release 2.43 appears and i release the reset button
      10 - upload the firmware to the box.
      11 - wait a little to finish and the box to load.
      12 - End
      Hope it helps
      regards
      • gefattern
        gefattern commented
        Editing a comment
        Hi , Driver Assistent 2.45 , what is that , typing error ???
        gefattern
      Rockchip Driver Assistant is also known as RK Driver Assistant. It is a small utility that allows you to install the correct Rockchip Driver on your pc
        Ok I managed to get in maskrom mode but when it starts flashing, it says download boot fail! I think I completely ruined it now!! Any ideas?
          Hi Guys,happy Sunday
          Now England vs Panama!
          -This time I'v successed and upgraded my Device according to "Hrodrigues" description;first off all I'v to thanks this guy
          -For upgrading I'v used
          >Android Tool Release v2.43
          >Driver Assistance v2.45
          and FW dated of "20180525" I'v used this one (but Rodrigues given 20180522 !!!) I do not what different???
          >used one USB3.0 cable both end "MALE"!!!>>this cable used between Device to PC(Desktop-OS;WIN7 Ultimate)
          >used one TypeC(3.1)cable one end FEMALE and the other end TypeC socket>>this adapter between Device and USB3.0 cable and goes to Desktop's USB3.0 port as well
          Note;when I'v useing above two program(Tool and Assistance) there is no any problem and connection successed including file transfer(first to upload to Tool than to my Box)
          Flashing Device duration;it takes about 2minutes only!!!
          After flashing,Device display shows to "LOAD" and do not react! dont worry about this,you just close your programs from your PC and remove your Device from PC too
          And re-connect your Device to your TV and make the necessary connections
          When your Device re-opened than its turn to Default(Factory)reset and wait couple of miniutes and finally your Device will be opened!
          Check from settings "ABOUT";then you will see 20180525(mine 25 but Rodrigues see 22 !!!) so can someone explain this??
          NOTE;therefore for flashing listing pls follow Hrodrigues descriptions! one by one carefuly read and apply in fact its very easy
          For after flashing,for "KODI" use;sorry I'hvny check yet! tonight I'll check it after Matches
          First I'll check(to install) 18.0 LEILA and if not work properly than I'v to return 17.6
          >First BUG;Screensaver;do not work before and now!!! I set it "after 5min." but do not react anymore now and before! but it doesnt affected me!
          See you later....
            #bergamesk it was wrong typing. I've correct it, is 25 not 22.
            Your welcome. Hope it can help more people.
            Regards
              Hi ,
              first i know what Drivers are , i have them nearly all , but i never
              heard about a Version with Number 2.45 , so can you please
              upload only this Drivers , that i can use them for flashing , when
              my Cable arrives , would be great , thanks ,
              greetings / gefattern
                Hi ,
                sounds strange , did you "eraseFlash" before flashing the Rom ???
                good luck / gefattern
                  Hi ,
                  Here my used tools links for Android Tool Release(2.43) and Driver Assistance(2.45)
                  DepositFiles provides you with a legitimate technical solution, which enables you to upload, store, access and download text, software, scripts, images, sounds, videos, animations and any other materials in form of one or several electronic files.
                  or
                  https://k2s.cc/file/ad11557fa0954/An...nstall2.45.rar
                  or
                  https://rg.to/file/2670d35efbb77f769...l2.45.rar.html
                  My FW version "20180525"
                  and dont forget to use
                  >TypeC Adapter
                  >Male-Male USB3.0 Cable (I dont know if Male-Male USB2.0 Cable work!)
                    Hi ,
                    Also strange to me!
                    I'v just "Upload" the FW only!
                    I didnt use "ERASE FLASH" !!
                    I just upload FW file to the Tool than click it Update(or Upgrade)only and it works
                    So asking you does it necessary first ERASE and than UPGRADE???
                      FYI
                      when I'v flashed my Device than one program appeared(downloaded)>> "SuperSU" whats is this guys??
                      checking from GooglePlayeStore;"SuperSU" request to Update!! till now I do not Update it,while I'm not sure that
                      Or is it necessary to be Updated?
                      p.s;now tried to Update but it doesnt work! "update failed"
                      Also I didnt unisntalled this program!
                        I use a type c to usb male cable without a usb c adapter, I use just one cable. Maybe this is the problem?
                          In this Thread>>Page 11 post no;152 check this Adapter TypeC
                          as one end TypeC and the other end is USB3.0 Female
                          So,you need this Adapter and also you need 1 USB3.0 MALE-MALE Cable
                          Male-Male Cable connection between your PC/Laptop etc., with your Device's TypeC Adapter
                          well in this config.works well for me
                            Hi ,
                            first SuperSU is needed for "root" , Update was only the App in Store ,
                            or did it ask to update the Binarys ??? the App update is needed , i am
                            sure after this u got the "Binary" update Message , until now RK3399
                            always cause Bootloop with updated SUs , if this Rom shall do the
                            same ??? but it shall help , if u after the update of Binarys , first and
                            without reboot convert the SuperSU to SystemApp , this can be done
                            in Settings of SuperSU . This Hint was given in the CSA96 Thread ,
                            i think , good luck / greetings / gefattern
                            PS : "eraseFlash" is a must between different Rom Versions .
                              Hi gefattern
                              -SuperSU is still in Device and I tried to uninstall but failed and now as it seems that SuperSU should be stay in Device,OK I got it
                              -BUT,it says "need update" when I check GooglePlayStore than I click it but it doesnt update! why I dont know?
                              Update doesnt work at present
                              -My Device now work well and I do not see any "Bootloop" effect
                              So until now I do not understand anything for SuperSU!!
                              So,simply how do I effect those SuperSU Update???
