X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
    Hi to all ,
    for all who wants to know , i was not able to update the su Binarys ,
    it failed , offline & online , strange , so i was not able to convert to
    System App because it does not start before , other strange behavior ,
    TitaniumBackup does not even show up SuperSU , strange , someone
    else with this behavior ???
    greetings / gefattern
    • trebor
      trebor commented
      Editing a comment
      Super user and A7 have had a long troubled relation ship
    Hi ,
    here is what i mean : Click image for larger version
ID:	733606Click image for larger version
    hope you understand now , the white one is on the left , it can only
    be opened when "moreSettings" is activated , this is the stock one ,
    the other is extra installed in System and has only in the "Display"
    Settings the "HDMI" settings , why making extra Settings for only
    one Function , why not adding it to the "moreSettings" , saves for
    sure some space and work , and looks better ,
    OK understood danke+
    But this is not any problem for me even I'm not looking this settings too such where is located
    I think "More Settings" are unique and all Android TVBoxes are same though!
    Note;after "rooted" now Display>>Adavanced Settings;came to effective! now you can adjust your personal taste settings
    to this menu but before(with Stock FW)this menu doesnt effective and cant adjust settings! strange
    Yesterday I'v already checked with MXPlayer(installed Device system) and with Kodi;all my applied/adjusted sets effective
    so it works
      Hi to all ,
      Same me!
      SuperSU doesnt update!
        Originally posted by bergamesk View Post
        Same me!
        Hi ,
        i already thought that and what about all the other behaviors
        i discribed before , do you have the same too ???
        I already wrote in the FW Thread of X99 , really hope the Devs
        from GB will help to make this Rom better .
          well I wish!
          Hope GB or another ppl have take this Device in hand!
          It really need this!
          Seems RK3399 Devices no more chances to development!
          So have to wait
            yes. make this Rom better .
            • gefattern
              gefattern commented
              Editing a comment
              please write this once more on the Geekbuying Rom Site here , thanks / gefattern
            so it works
            Hi ,
            first , it was no Problem for me , i only wanted to show , how
            stupid the Roms are programmed , without thinking .
            Example , if the Devs know this Box has no 4G Modem , or any
            other Modem support why not deleting all this not needed SIM
            Functions off the Rom . I know about this "Advanced Settings"
            but why not adding this to the Stock Settings , ready ,
            no need for extra "tvSettings" . I am sure that in your Language
            are as many Errors , or not translated parts , as in German .
            Did you find a Screenshot Button , or any Settings where this
            can be done ??? , i not , thats all first , have a nice Day ,
              This Box has a lot of issues!
              Now I'm already started to find and buy another Box(RK3399) but I'm not lucky for that
              Just a few Brand RK3399 Box in the market and I'm scare how to buy!
              RK3399 boxes still in development progress!
                Hi ,
                if you really a full Time Kodi User , why not use a cheap AML Box and install
                LE to internal , runs flawless on most AML Boxes , better hold your Money ,
                maybe a Dev. brings in Future a well programmed RK3399 Rom , hopefully ,
                something else , do you have Screenshot / Settings ???
                  I was just going to buy rkm mk39 but I emailed them to make sure they have YCbCr 8 and 10 bit settings but they removed them just like h96 max in last firmware update. Video quality is very important so I will not buy rkm mk39.
                  I will never buy amlogic box because video quality is absolutely horrible
                  My zidoo h6 pro has awesome video quality so I like using it
                    you right+
                    AMLs picture quality low and not to worth compare against RK3399
                    RK3399 satisfied me for the video quality,but it has so many issues! even Android work also not stable/good!
                    Seems need more time for develepment for the RKs
                    In the past I'v already used Zidoo too and picture quality so good
                    >>8/10-bit;X99 does not supprted 10-bit!!! and I think no one has supported 10-bit
                    I'v selected>>> 8-bit/YCbRc4:4:4 or 8-bit/YCbRc4:2:2
                    I do not know which one is stable/work good!
                    Note;my ext.sources(fm HDD) SD&HD(mostly 720/1080)
                      well I'v already check this RKM MK39 Box;seems on paper and reviews good device!
                      1-Rooted;YES
                      2-OTA;NO
                      3-KODI;YES without any issue
                      >Internet performance;super
                      With WiFi
                      Video Quality;I'm sure that excellent as well!
                      8/10-bit;no any definite info!
                      Now I use X99(it was so tired me since 2 months!) lot of issues,Kodi problem! Speedtest very bad! ......
                      So might be I'll buy MK39
                        I have the X99 RK3399 and it works flawlessly, i know some people get bad ones, but i must be lucky that it works real good...
                        Sorry didn't mean to but in on your conversation
                          Hi ,
                          we all know that this PCBs run well , but it is the Firmware that is full of Bugs ,
                            1-Rooted;YES
                            2-OTA;NO
                            With WiFi
                            Why would you consider this? It's $149 ?? The Nvidia Shield is just $199 and totally blows away all these RK3399 boxes
                            I got the 2015 Shield refurbished for under $150 and I have the Alfawise H96MAX RK3399 and their is no comparing them, the Shield is 10x better at everything
                            I watched a bunch of 4k videos on the 4th from Youtube on the Shield and never had a single problem.
                            I will never consider another box that's not Android TV os and True 4k ready (Netflix and YouTube)
