X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
    external FAN for this box
      Hi ,
      WoW , what a Fan , why not from below ???
      greetings / gefattern
        Hi again ,
        here are my (bad Quality) Pictures of Chase Mod & Fan :
        Click image for larger version  Name:	IMG_20180701_173412.jpg Views:	1 Size:	90.0 KB ID:	735720Click image for larger version  Name:	IMG_20180701_175520.jpg Views:	1 Size:	114.8 KB ID:	735721
        Click image for larger version  Name:	IMG_20180701_094824.jpg Views:	2 Size:	80.0 KB ID:	735722
          Hi once more ,
          please post any Bug or even bad or no Translations in your Language
          in the Geekbuying X99 FW Thread , so maybe the next Version of FW ,
          has fully working SuperSU and some more fixes and improvments .
            My Box with 3 holes on top!
              Hi to all X99s ,
              here is a list with Apps that i deleted from System :
              from Apps :
              1.Basic Dreams
              2.PartnerBookmarkProvider
              3.BookmarkProvider
              4.Calculator
              5. G Contact Sync Provider
              6. G Calender Sync Provider
              7.PinYin IME
              8.RFTesttool
              9.RKDeviceTest
              10.SkyFileBrowser
              11.SkyLauncher4 (of course i installed before Apex to Systemlauncher)
              12.Sky Kodi
              13.SkyReinstall
              14.TalkBack
              15.WallpaperBackup
              16.UserDic.Provider
              from priv.Apps :
              1.CalenderProvider
              2.ContactProvider
              3.ChangeLEDStatus
              4.DeviceTest
              5. G FeedBack
              6.Velvet
              7.MediaCenter
              8.MediaC.Provider
              9.Provision
              10.SkyKirinTest
              11.SkySettingsWiz.New
              12.Stresstest
              and of course the not needed Apps in "preinstalledApps"
              i am no Dev. but i am sure it can be more ??? and i really want to know
              what this kind of Apps doing : CTSShinPrebuilt & CTSShinPrivPrebuilt ???
              I think that my Bug and translation error Report is ready till Weekend .
              If i disable / enable the Displaykeyboard Function it still pops up , so
              for sure another Bug .
                X99 kinda BUG Box!
                I do not like this Box but I like "RK3399" only
                And thanks for your info of the deleted Apps. list
                But asking you for the Apps.;does it necessary to delet them??
                  Originally posted by bergamesk View Post
                  X99 kinda BUG Box!
                  Hi ,
                  not really , but i always do that , because i not need all this stupid Apps like ,
                  Calculator / Calender / Contacts / Velvet , this App is the small bar on top
                  of Homescreen / PinYin IME , is a chinese Keyboard , Test.apks , and more .
                  I made this for others that want to uninstall not needed Apps , so they know
                  what is possible ,
                    Hi guys
                    Today,when I was opened the Box than I got a warning msg from "SuperSU" that there is an updating!
                    but than msg disappeared! and it says after 15min.this warning again will be opened and now I'm awaiting
                    for this
                      Hi guys
                      for this
                      Hi ,
                      that is normal , but the update will fail , same on my Box , not possible to update SU binarys & SuperSU ,
                      try and report , but sure it will be the same ,
                        OK got it+
                        Thx
                          Hi ,
                          sh.. , have to do flash once more new , deleted , my mistake , the Apps that show the files in Galerie and Player Apps ,
                          learning by doing , but i am nearly ready with my Bug report for GBuying and Mo123 , hope it helps ,
                            Any recommendation for the Picture Viewer apk.
                            I'v tried "QuickPic" its nice for photos but "Slide Show" function does not work on my X99 !!!
                            I'v always used to this apk my previous boxes and no any issue but this time when I'v load this apk.
                            than all functions OK but but SlideShow function does not work,so than I'v unistalled which was not
                            stable workable
                            Therefore I'v also tried some of other PhotoViewer apk. but I do not like it
                            Till today I do not find any proper/stable(with X99 damned Box!!) Photo Viewer programme
                            All suggestions will be higly appreciated
                              Hi ,
                              what about "simpleGallery" ???
                              gefattern
                                OK I'll check it thx+
                                Actually QuickPic. very good apk. but why Slideshow doesnt work,I dont know?
                                Again another X99 BUG might be?
