X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
Originally posted by raruba View Post
Update: it worked....I am able to update with google play store, also updated google crome
so the Update with LuckyPatcher worked ??? , but now you can not update your Apps over Playstore ,
so how did you update Chrome ???
thanks / greetings / gefatternLast edited by gefattern; 13 November 2019, 23:46.
Anyone know whats this about, Do you think its actually 8.1 android? https://www.alibaba.com/product-deta...745652327.html
Hi ,
thanks / greetings / gefatternLast edited by gefattern; 13 November 2019, 23:47.
Originally posted by ldrrp View PostAnyone know whats this about, Do you think its actually 8.1 android? https://www.alibaba.com/product-deta...745652327.html
Sure do wish that was true.....that would be a big plus for this BOX.....Do you where to download the firmware???
No idea, i emailed the seller asking for firmware because i "bricked" my device. If i could believe it to be true i would buy it and just pull the firmware down.
Post #883.......give it a try
There's a way to unbrick this box. https://forum.freaktab.com/forum/tv-...i-bt4-1/page59
Hi ,
really frustrated , can not understand what he did with LuckyPatcher , what Function he used
to update Playstore , can not find anything to download new Playstore with LuckyPatcher ,
installed the latest Version 8.6.0 , what must i press that the Playstore downloads Update ???
Hi ,
please one good to understand Tutorial , there is no Remove & Install section in LuckyPatcher , what is Playmarket , never heard ???
please if you dont speak or write English good enough , use better Translator , what you wrote above makes NO SENSE ,
is it possible that you discribe it once STEP by STEP , thanks hopefully , your English is HORROR
greetings / gefatternLast edited by gefattern; 14 November 2019, 02:01.
did you get a answer of the Seller , do they really sell it with 8.1 ???
press thumbs that you get a Link ,
good luck / gefattern
Hi ,
There are currently 2140 users online. 0 members and 2140 guests.
