Etcher is a tool to create bootable SD card from img.gz or img
X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
Originally posted by npcomplete View Post
Here you go:? Android-9.0-X99-20191206.img.gz
It's an img.gz file this time so you can directly use Etcher. Also, I've only tried this on an SD card. Let me know
Originally posted by npcomplete View PostSure you can extract img.gz to img and flash the img to internal flash.
tried portable version and reg. versionLast edited by gefattern; 08 December 2019, 02:16.
Originally posted by raruba View Post
This program will not see the BOX....loads the IMG file but doesn't see the box....I'm using Windows 10 pro 32bit
not to Box , to SDCard or similar , the File is 4.57GB big , really big ???
greetings / gefattermLast edited by gefattern; 08 December 2019, 02:16.
Originally posted by gefattern View PostHi ,
small Info , it worked , got it booted from SD , look like all is running well , Wifi , BT , still some English , not translated , but is it really possible to flash it with Tool , dont know , have to try , but before , backup , Infos from others would help ,
good luck / gefattern
UPDATE: So the box runs off the SD CARD, the image isn't flashed to the BOX.....sorta weird....like having 2 systems on the box.
Wish there was a way to flash it to the box....looks like it runs pretty GOOD.
Front Display does not work.Last edited by raruba; 08 December 2019, 14:44.
I got mine loaded into Etcher but Etcher does not see the BOX, but I did get to load on the SD card....will let you know how it works.
Etcher is a SDBoot Tool , not sure if the .img can be flashed with PCTool , big File , but normal it must work , did you tried to flash it with Tools ??? ,
greetings / gefattern
Hi ,
So you must write the firmware with etcher to a micro-sd card or a removable emmc and attach it to your boards empty slot.
Rockchip tools can't flash these images.
RockPi 4 uses removable emmc and micro-sd cards to boot firmware.
sounds not nice , would be better to use it on internal , the File is 4.5GB big , it is a .img File ,
we really need a A9 Rom for internal ,
press thumbs ,
But good try. I will try anything on this BOX...lol
If you can make an IMG file for a SD card seems someone could make one for the internal flash IMG file....wish I knew how.
There are currently 2719 users online. 0 members and 2719 guests.
