X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
    Hi ,
    it not works and ES for sure not , it is a AD & Spy Tool , Internet reported month ago ,
    greetings / gefattern
    I
    I have been using ES File Explorer for many many years.
      Hi ,
      Help Help , i am bricked , no LoaderMode possible , what Pins must be shorten , thanks for help ,
      back to life , with User "beppin" way , but
      really silly to do , i only had luck , because , the wire i used slipped from my Fingers and hit the right points , Power & USB already was plugged , if i can get my stock BoxSettings Backup as before , i stay on it , really
        Hi ,
        i found a Way to delete the unwanted SystemApps , i use my SystemAppMover , to convert them to UserApps , so i can uninstall them , i get nearly back how it was before ,
          Hi ,
          Good for you, glad to hear that. Hope cubelibre can make a AOSP ROM for this box.....he must be very good at this shit....because no one else would even try to make a android 9 for this box.
            Hi ,
            does anyone know this Version 24.4.19 ,
            found it , anyone use it ???
              Hi ,
              https://yadi.sk/d/xV1K6mtI3kfWmA/t9_...Akodi18.0).img
              looks like april 24th 2019 (20190424) for the T9 Box maybe, don't think the T9 box ever had RK3399 chip in it though....not sure......is it Android 9?
                Where did you find it????
                  Hi ,
                  somewhere here , i think ,
                  it is a A7 Rom , has "root" , without Superuser App , and below the typic Navbar ,
                  so called , same shit as before ,
                    Hi ,
                    Sorta figured that
                      Sure do hope cubelibre can get AOSP running on this box.
                        Originally posted by cubelibre View Post
                        read post https://forum.freaktab.com/forum/tv-...793#post816793
                        give me link to this rom , im try it .
                        Here's a couple of links for X99 firmware, the last one is not rooted
                        Посмотреть и скачать с Яндекс Диска
                          Well gefattern, I think cubelibre has left us.....hope we didn't scare him off
                            you have to first install the FileLinked (DroidAdmin)
                            Then you can get and Kodi addons or IPTV app on TV Box
                              cubelibre, I got your firmware running real good..by the way it runs real good..only thing is I can't add widgets or background pics to the launcher....I'am using ADW Launcher.....Any IDEA'S?????
                                Hi ,
                                Hows things going with the box??? Have u heard anything from cubelibre???
