Linux for RK3188 based TV boxes
Originally posted by mmm123 View Post
Originally posted by linuxium View PostFYI the files in /lib/modules in my RFS are the Android modules - they are there for compatibility with some of my earlier work however they are not required in your circumstances. The Linux modules should be used in preference to the Android ones as mmm123 says.
I figure it out by my self
I test the 'sudo insmod /lib/modules/8188eu.ko' and I see it at lsmod as wlan or wifi but not as 8188eu and it don't work ...RK3288 Devices
- Overview BOX (LINK !)
partitions
Ok, perhaps I'm on the wrong way, but your kernel at recovery is able to boot
- /dev/sda
- /dev/mmcblk0
If I use partitions it did not work???
And I don't understand why?
I unpack your recovery.img with 'Android Image Kitchen v1.8' so I get the kernel and the ramdisk.
If I have a look at the '\init' I find out that you
1.) looking at '/proc/cmdline' for 'root' and set the ROOT=/dev/disk/by-label/${value#LABEL=} (after you set it with LABEL and after you have a look at '\')
2.)
maybe_break mount
log_begin_msg "Mounting root file system"
. /scripts/${BOOT}
parse_numeric ${ROOT}
maybe_break mountroot
mountroot
log_end_msg
(and BOOT is only set if '/dev/nfs' in the '/proc/cmdline')
and at 'scripts\local-premount\fixrtc' you also look for 'root'...
with an extract at shell both variables seems to be good, so I don't understand way it only work at sda and mmcblk0 instead of partitions (and I thought that I have run it at one of my beginning test at mmcblk0p1 too, but it seems so that this is a mistake...)
Code:for x in $(cat /proc/cmdline); do echo "x: "$x"" case $x in init=*) init=${x#init=} ;; root=*) ROOT=${x#root=} echo "ROOT: "$ROOT"" case $ROOT in LABEL=*) ROOT="${ROOT#LABEL=}" echo "ROOT: "$ROOT"" # support any / in LABEL= path (escape to \x2f) case "${ROOT}" in */*) echo "case at /" if command -v sed >/dev/null 2>&1; then ROOT="$(echo ${ROOT} | sed 's,/,\\x2f,g')" else if [ "${ROOT}" != "${ROOT#/}" ]; then ROOT="\x2f${ROOT#/}" fi if [ "${ROOT}" != "${ROOT%/}" ]; then ROOT="${ROOT%/}\x2f" fi IFS='/' newroot= for s in $ROOT; do newroot="${newroot:+${newroot}\\x2f}${s}" done unset IFS ROOT="${newroot}" fi esac ROOT="/dev/disk/by-label/${ROOT}" echo "ROOT: "$ROOT"" ;; esac esac done echo "ROOT: "$ROOT"" for x in $(cat /proc/cmdline); do case ${x} in root=*) value=${x#*=} # Find the device node path depending on the form of root= : case ${value} in UUID=*) ROOTDEV=/dev/disk/by-uuid/${value#UUID=} ;; LABEL=*) ROOTDEV=/dev/disk/by-label/${value#LABEL=} ;; *) ROOTDEV=${value} ;; esac ;; fixrtc) BROKEN_CLOCK=1 ;; esac done echo "ROOTDEV: "$ROOTDEV""
Code:x: initrd=0x62000000,0x00800000 x: root=LABEL=linuxroot ROOT: LABEL=linuxroot ROOT: linuxroot ROOT: /dev/disk/by-label/linuxroot x: init=/sbin/init ROOT: /dev/disk/by-label/linuxroot ROOTDEV: /dev/disk/by-label/linuxroot
Code:ls -al /dev/disk/by-label total 0 drwxr-xr-x 2 root root 60 Jan 3 21:38 . drwxr-xr-x 6 root root 120 Jan 3 21:02 .. lrwxrwxrwx 1 root root 9 Jan 3 21:38 linuxroot -> ../../sda
Code:ls -al /dev/mmc* brw-rw---- 1 root disk 179, 0 Jan 3 21:36 /dev/mmcblk0 brw-rw---- 1 root disk 179, 1 Jan 3 21:36 /dev/mmcblk0p1
Code:ls -al /dev/disk/by-label total 0 drwxr-xr-x 2 root root 60 Jan 3 21:36 . drwxr-xr-x 6 root root 120 Jan 3 21:02 .. lrwxrwxrwx 1 root root 15 Jan 3 21:36 linuxroot -> ../../mmcblk0p1
ls /dev/disk/by-label
lrwxrwxrwx 1 15 linuxroot -> ../../mmcblk0p1
drwxr-xr-x 5 100 ..
drwxr-xr-x 2 60 .
If I start up the device without a RFS and I plug sda and type 'init' at {initramfs} only errors...
PS: --------
Generally I identify the problem:
My first tries I do with a 4GB SD instead of the now used 32GB.
With 'sudo fdisk -l /dev/mmcblk0' at the 4GB I get
Code:Device Boot Start End Blocks Id System /dev/mmcblk0p1 63 7882751 3941344+ c W95 FAT32 (LBA)
Code:=> ls -al /dev/mmc* brw-rw---- 1 root disk 179, 0 Jan 4 00:22 /dev/mmcblk0 brw-rw---- 1 root disk 179, 1 Jan 4 00:22 /dev/mmcblk0p1 => ls -al /dev/disk/by-label total 0 drwxr-xr-x 2 root root 60 Jan 4 00:22 . drwxr-xr-x 6 root root 120 Jan 4 00:22 .. lrwxrwxrwx 1 root root 15 Jan 4 00:22 linuxroot -> ../../mmcblk0p1
I will figure it out tomorrow, but for to day, I can sleep
PPS:--------
No, the 4GB SD also starts with 'W95 FAT32' ... ???
No idea, what kind of problem it is at the 32GB...Last edited by no_spam_for_me; 07 March 2014, 05:36.RK3288 Devices
PPPS:
WinXP SP3
Generally writing the img with WinHex:
With CreateMini for >=1 partitions:
Everything is fine, if SD / USB is <=8GB (1,2,3 Partitions)
System (at 'sudo fdisk -l')
W95 FAT32
or
Linux (ext2 at CreateMini)
BUT with SD / USB >=16GB it doesn't work...
To reset the partition to 1 at <=8GB with e.g. 'HP USB Disk Storage Format Tool 2.2.3' or 'Rufus'
=> only boot to linux if e.g. Ext2Fsd is running (and detach, attach, detach USB/SD)
USB-16GB / SD-32GB no chance to boot up with a partition (only "hole" device with 'Win32 Disk Imager 0.9 binary')
(ok, I get it at the sd with 1 partition, but I can not remember what and how I made it and now because of the test it is away...)
MiniTool Partition Wizard 8.1.1 Server
SD-32GB
- (primary, fat32 (with ext no drive-letter possible))
- WinHex restore image...
-same procedure
USB-16GB "hole" device with 'Win32 Disk Imager 0.9 binary' and an existing backup
- sudo resize2fs /dev/sda
- copy image-file to it (FTP)
- sudo apt-get install gparted
- insert SD-32GB
- dash Gparted (5GB, primary, ext4, linuxroot)
- sudo dd bs=4M if=linuxium-ubuntu1204-desktop-rfs-BASIS.img of=/dev/mmcblk0p1
- sudo reboot
- detach USB
-same procedure ... fu** offffff
Code:=> ls -al /dev/mmc* brw-rw---- 1 179, 1 /dev/mmcblk0p1 brw-rw---- 1 179, 0 /dev/mmcblk0 => ls -al /dev/disk/by-label lrwxrwxrwx 1 15 linuxroot -> ../../mmcblk0p1 drwxr-xr-x 5 100 .. drwxr-xr-x 2 60 .
RK3288 Devices
dmesg
Perhaps someone can have a look at it (and find helping information)...
What I'm wondering in is that first:
Code:[ 1.493087] msdos_partition..461... ==== Begin to parse sdcard-partition. [mmc0] [ 1.493280] msdos_partition..530... ==== The sdcard has MBR. [mmc0] [ 1.493411] msdos_partition..543... ==== partition-1, size=30930944KB [mmc0] [ 1.493552] msdos_partition..571... ==== main partition-1....[mmc0] [ 1.493683] mmcblk0: p1
Code:[ 1.942692] EXT4-fs (mmcblk0): error loading journal
This is my mount for the dmesg > ...
Code:[ 48.578371] EXT4-fs (mmcblk0p1): recovery complete [ 48.620529] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
Attached FilesRK3288 Devices
Originally posted by no_spam_for_me View PostPerhaps someone can have a look at it (and find helping information)...
btw missing journal should not be a problem since it is automatically fixed on boot.
Originally posted by mmm123 View Postbtw missing journal should not be a problem since it is automatically fixed on boot....
I try it with GpartEd and
Code:mkdir ~/img sudo mount -o loop linuxium-ubuntu1204-desktop-rfs-BASIS.img ~/img mkdir ~/sd sudo mount -t ext4 /dev/sdb1 ~/sd sudo cp -r -a ~/img/* ~/sd sudo umount ~/sd sudo umount ~/img sudo tune2fs -L linuxroot /dev/sdb1
Code:sudo dd bs=4M if=linuxium-ubuntu1204-desktop-rfs-BASIS.img of=/dev/sdb1
mkdir ~/sd
sudo cp -r ~/img/* ~/sd
sudo umount ~/sd
sudo umount ~/img
mkdir ~/img
mkdir ~/sd
mkfs.ext4 /dev/sdb1
tune2fs -L "linuxroot" /dev/sdb1
mount /dev/sdb1 ~/sd
cd ~/img
tar -cfps - . | ( cd ~/sd ; tar -xpvf - )
cd ~
umount sd
umount imgLast edited by mmm123; 08 March 2014, 17:26.
Originally posted by mmm123 View Postif you have running linux, use linux fdisk/cfdisk to partition USB drive, then use linux tools to format as ext4
=> 3 x 10GB
sudo mkfs.ext4 /dev/mmcblk0p2
sudo tune2fs -L linuxroot /dev/mmcblk0p2
same procedure
Code:: [ 1.472707] mmc_attach_sd..1219.. ===== Begin to identify card as SD-card. [mmc0] [ 1.488462] gp_rknand_info = : 0xee61c100 [ 1.488622] request IRQ_NANDC irq , ret=0......... [ 1.488764] FTL INFO:Version = 438,Date = 20130516 [ 1.488923] FlashCopyProgBuf1=0xc1483000 [ 1.489091] ATime: 40 ns AHB: 150 timming: 1082 [ 1.489191] No.1 FLASH INFO:ad de 94 eb 74 [ 1.489281] No.2 FLASH INFO:ff ff ff ff ff [ 1.489365] No.3 FLASH INFO:ff ff ff ff ff [ 1.489457] No.4 FLASH INFO:ff ff ff ff ff [ 1.489971] ATime: 32 ns AHB: 150 timming: 1061 [ 1.490237] ATime: 32 ns AHB: 150 timming: 1061 [ 1.490326] randomizer = 2 , EccBits = 28 pSpec->pReadRetrial = bf026360 [ 1.500154] rk29_sdmmc_change_clk_div..1935.. newDiv=0, newCLK=37500Khz [sd_mmc] [ 1.500415] mmc0: new high speed SDHC card at address 59b4 [ 1.500911] mmcblk0: mmc0:59b4 29.4 GiB [ 1.502659] [ 1.502665] msdos_partition..461... ==== Begin to parse sdcard-partition. [mmc0] [ 1.502876] msdos_partition..530... ==== The sdcard has MBR. [mmc0] [ 1.503011] msdos_partition..543... ==== partition-1, size=9765624KB [mmc0] [ 1.503165] msdos_partition..571... ==== main partition-1....[mmc0] [ 1.503311] msdos_partition..543... ==== partition-2, size=9765632KB [mmc0] [ 1.503465] msdos_partition..571... ==== main partition-2....[mmc0] [ 1.503596] msdos_partition..543... ==== partition-3, size=11400704KB [mmc0] [ 1.503752] msdos_partition..571... ==== main partition-3....[mmc0] [ 1.503887] mmcblk0: p1 p2 p3 [ 1.504575] mmc_rescan_try_freq..1718.. ===== Initialize SD-card successfully. [mmc0] : [ 1.873850] EXT4-fs ([U]mmcblk0[/U]): error loading journal : ls -al /dev/disk/by-label lrwxrwxrwx 1 15 linuxroot -> ../../mmcblk0p[B]1[/B] drwxr-xr-x 5 100 .. drwxr-xr-x 2 60 .
and mmcblk0p1 instead of mmcblk0p2
I don't know, is it a problem of *.ko, *.so or kernel...???Last edited by no_spam_for_me; 09 March 2014, 00:41.RK3288 Devices
delete because bullshitRK3288 Devices
I don't know, I don't think so, because if I remember correctly it is the same with USB 16GB (sda, also a USB-microSD-reader with the 32GB) and SD without partition(s) at 32GB (mmcblk0) work...RK3288 Devices
Originally posted by no_spam_for_me View PostI don't know, I don't think so, because if I remember correctly it is the same with USB 16GB (sda, also a USB-microSD-reader with the 32GB) and SD without partition(s) at 32GB (mmcblk0) work...
Of course I use 1st partition for linux
root@rk3188:~# fdisk -l /dev/mmcblk0
Disk /dev/mmcblk0: 31.6 GB, 31611420672 bytes
255 heads, 63 sectors/track, 3843 cylinders, total 61741056 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
/dev/mmcblk0p1 * 63 60548984 30274461 83 Linux
/dev/mmcblk0p2 60548985 61741055 596035+ 82 Linux swap / Solari
[ 1.464320] mmc_attach_sd..1219.. ===== Begin to identify card as SD-card. [mmc0]
[ 1.489094] gp_rknand_info = : 0xee21c100
[ 1.489270] request IRQ_NANDC irq , ret=0.........
[ 1.489415] FTL INFO:Version = 438,Date = 20130516
[ 1.489863] FlashCopyProgBuf1=0xc1483000
[ 1.490044] ATime: 40 ns AHB: 150 timming: 1082
[ 1.490150] No.1 FLASH INFO:98 de 84 93 72
[ 1.490245] No.2 FLASH INFO:ff ff ff ff ff
[ 1.490337] No.3 FLASH INFO:ff ff ff ff ff
[ 1.490428] No.4 FLASH INFO:ff ff ff ff ff
[ 1.490922] ATime: 32 ns AHB: 150 timming: 1061
[ 1.491203] ATime: 32 ns AHB: 150 timming: 1061
[ 1.491302] randomizer = 2 , EccBits = 28 pSpec->pReadRetrial = bf025c34
[ 1.491359] rk29_sdmmc_change_clk_div..1935.. newDiv=0, newCLK=37500Khz [sd_mmc]
[ 1.491487] mmc0: new high speed SDHC card at address 59b4
[ 1.492021] mmcblk0: mmc0:59b4 SD 29.4 GiB
[ 1.493623]
[ 1.493628] msdos_partition..461... ==== Begin to parse sdcard-partition. [mmc0]
[ 1.493836] msdos_partition..530... ==== The sdcard has MBR. [mmc0]
[ 1.494026] msdos_partition..543... ==== partition-1, size=30274461KB [mmc0]
[ 1.494243] msdos_partition..571... ==== main partition-1....[mmc0]
[ 1.494399] msdos_partition..543... ==== partition-2, size=596035KB [mmc0]
[ 1.494547] msdos_partition..571... ==== main partition-2....[mmc0]
[ 1.494680] mmcblk0: p1 p2
[ 1.495269] mmc_rescan_try_freq..1718.. ===== Initialize SD-card successfully. [mmc0]
[ 2.067658] EXT4-fs (mmcblk0p1): INFO: recovery required on readonly filesystem
[ 2.075333] EXT4-fs (mmcblk0p1): write access will be enabled during recovery
[ 3.688115] EXT4-fs (mmcblk0p1): recovery complete
[ 3.714215] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.013019] Adding 596028k swap on /dev/mmcblk0p2. Priority:-1 extents:1 across:596028k SS
[ 11.341133] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
root@rk3188:~# cat /proc/partitions
major minor #blocks name
179 0 30870528 mmcblk0
179 1 30274461 mmcblk0p1
179 2 596035 mmcblk0p2
root@rk3188:~# ls -l /dev/disk/by-label/
total 0
lrwxrwxrwx 1 root root 15 Jan 1 2000 linuxroot -> ../../mmcblk0p1
lrwxrwxrwx 1 root root 15 Jan 1 2000 swap -> ../../mmcblk0p2
Boot by boot.img & kernel.img OR by recovery.img (that's what i use)?RK3288 Devices
Originally posted by no_spam_for_me View PostBoot by boot.img & kernel.img OR by recovery.img (that's what i use)?
Unless android is screwing card, which is not very likely.
There are currently 2103 users online. 2 members and 2101 guests.
