Thanks for your help.
I now have my working kernel for picuntu.....
# Start a grubesque menu TIMEOUT=9 clear echo echo "----------------------------------------------------------------------" echo "-------Boot menu:-----------------------------------------------------" echo "----------------------------------------------------------------------" echo "----------------------------------------------------------------------" echo "------------ 1) Linux NAND (mtdblock2)... ----------------------------" echo "------------ 2) Linux HDD (/dev/sda1)... ----------------------------" echo "------------ 3) Enter your (/???/????)... ----------------------------" echo "----------------------------------------------------------------------" echo "----- Enter 1,2,3 to boot the selected OS... -------------------------" echo "----------------------------------------------------------------------" [ ${TIMEOUT} -gt 0 ] && echo "------Booted automatically in ${TIMEOUT} seconds... ---------------------------" echo "----------------------------------------------------------------------" read -n 1 -t ${TIMEOUT} ANSWER echo case "${ANSWER}" in 1) echo "----------------------------------------------------------------------" echo "--- Boot Linux NAND... -----------------------------------------------" echo "----------------------------------------------------------------------" BOOTTHE="/dev/mtdblock2" ;; 2) echo "----------------------------------------------------------------------" echo "--- Boot Linux HDD (/dev/sda1)... ------------------------------------" echo "----------------------------------------------------------------------" BOOTTHE="/dev/sda1" ;; 3) echo "----------------------------------------------------------------------" echo "--- Enter your (/???/???)... -----------------------------------------" echo "----------------------------------------------------------------------" read BOOTYOUR BOOTTHE=$BOOTYOUR ;; *) echo "----------------------------------------------------------------------" echo "------------------------ Auto boot -----------------------------------" echo "----------------------------------------------------------------------" echo "-------- Boot "/dev/mtdblock2" or set "/home/boot.def" ---------------" echo "----------------------------------------------------------------------" #Default boot mount -t ext4 /dev/mtdblock2 /mnt if [ -e /mnt/home/boot.def ] ; then BOOTDEF=`cat /mnt/home/boot.def` umount /mnt BOOTTHE=$BOOTDEF else BOOTTHE="/dev/mtdblock2" fi sleep 2 ;; esac
# Export relevant variables export ROOT=$BOOTTHE export ROOTDELAY=
# Parse command line options for x in $(cat /proc/cmdline); do case $x in init=*) init=${x#init=} ;; root=*) ROOT=${x#root=} ROOT=$BOOTTHE
There are currently 2675 users online. 0 members and 2675 guests.
