Linux for RK3188 based TV boxes
Code:$ make modules_install INSTALL_MOD_PATH=mod_fw INSTALL drivers/media/common/tuners/max2165.ko INSTALL drivers/media/common/tuners/mc44s803.ko INSTALL drivers/media/common/tuners/mt2060.ko INSTALL drivers/media/common/tuners/mt20xx.ko INSTALL drivers/media/common/tuners/mt2131.ko INSTALL drivers/media/common/tuners/mt2266.ko INSTALL drivers/media/common/tuners/mxl5005s.ko INSTALL drivers/media/common/tuners/mxl5007t.ko INSTALL drivers/media/common/tuners/qt1010.ko INSTALL drivers/media/common/tuners/tda18212.ko INSTALL drivers/media/common/tuners/tda18218.ko INSTALL drivers/media/common/tuners/tda18271.ko INSTALL drivers/media/common/tuners/tda827x.ko INSTALL drivers/media/common/tuners/tda8290.ko INSTALL drivers/media/common/tuners/tda9887.ko INSTALL drivers/media/common/tuners/tea5761.ko INSTALL drivers/media/common/tuners/tea5767.ko INSTALL drivers/media/common/tuners/tuner-simple.ko INSTALL drivers/media/common/tuners/tuner-types.ko INSTALL drivers/media/common/tuners/tuner-xc2028.ko INSTALL drivers/media/common/tuners/xc5000.ko INSTALL drivers/media/video/gspca/gspca_main.ko INSTALL drivers/scsi/scsi_wait_scan.ko DEPMOD 3.0.72+ $
The only file I see relating to the AP6210 is this file: include/config/ap6210.h
...and its blank.Last edited by tyeo098; 01 October 2013, 14:33.Buy me a beer with
DogeCoin: D6EeoEKcZJL234UhVFRV8Uy6HnfNurBS2y
or
BitCoin 17iQsUv7RoWVmDynfBS9qF88NxT4ETvhUn
Hi all!
First of all many thanks to mmm123, tyeo098 and others for their posts and links! Great job!
I have successfully flashed and booted my "Tronsmart MK908" with Debian on-board. We are planning to use this device as thin-web-client on the one of our projects.
After booting I had eth0 interface up and running (extrenal "ASIX AX88772 USB 2.0 Ethernet"). But the main goal is to have WiFi connection (because we have it on-board and it have to work!).
I did some investigations with many kernel options & builds but without success.
I can't get correct wifi module compiled..
So I have googled again and at the end I just did all as described in http://www.rikomagic.co.uk/forum/vie...598&f=2#p15102 and have WiFi interface up and working!
Here is some output from my device.
"Firmware" lies here:
Code:root@rk3188:/# ll /system/etc/firmware/ total 220 drwxr-xr-x 2 root root 4096 Oct 1 13:22 . drwxr-xr-x 3 root root 4096 Oct 1 13:21 .. -rw-r--r-- 1 root root 210524 Oct 1 13:08 fw_RK901a2.bin -rw-r--r-- 1 root root 1056 Oct 1 13:15 nvram_AP6210.txt
The location and names are defined in ..drivers/net/wireless/rkwifi/rk_wifi_config.c:
#define ANDROID_FW_PATH "/system/etc/firmware/"
#ifdef CONFIG_AP6210
sprintf(fw, "%s%s", ANDROID_FW_PATH, "fw_RK901a2.bin");
sprintf(nvram, "%s%s", ANDROID_FW_PATH, "nvram_AP6210.txt");
#endif
And WiFi module here:
Code:root@rk3188:/# cd /lib/modules/ root@rk3188:/lib/modules# ll total 572 drwxr-xr-x 2 root root 4096 Oct 2 08:48 . drwxr-xr-x 13 root root 4096 Sep 4 10:17 .. -rw-r--r-- 1 root root 577318 Oct 1 13:07 rkwifi.ko
Code:root@rk3188:/lib/modules# insmod rkwifi.ko root@rk3188:/lib/modules# tail /var/log/messages -n 50 ======================================================= Oct 2 09:43:36 rk3188 kernel: [ 2968.096304] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== Oct 2 09:43:36 rk3188 kernel: [ 2968.102678] ======================================================= Oct 2 09:43:36 rk3188 kernel: [ 2968.109045] RKWIFI WiFi driver (Powered by Rockchip,Ver 4.49.WFD) init. Oct 2 09:43:36 rk3188 kernel: [ 2968.115807] =========== WLAN placed in POWER ON ======== Oct 2 09:43:36 rk3188 kernel: [ 2968.125748] rk29sdk_wifi_power: 1 Oct 2 09:43:36 rk3188 kernel: [ 2968.379344] wifi turn on power Oct 2 09:43:36 rk3188 kernel: [ 2968.387379] rk29sdk_wifi_set_carddetect:1 Oct 2 09:43:36 rk3188 kernel: [ 2968.391503] mmc1: slot status change detected(0-1) Oct 2 09:43:36 rk3188 kernel: [ 2968.592565] Oct 2 09:43:36 rk3188 kernel: [ 2968.592576] drivers/mmc/core/core.c...1824.. ===== mmc_rescan Begin....[mmc1] Oct 2 09:43:36 rk3188 kernel: [ 2968.636597] Oct 2 09:43:36 rk3188 kernel: [ 2968.636607] mmc_attach_sdio..808.. ===== Begin to identify card as SDIO-card. [mmc1] Oct 2 09:43:36 rk3188 kernel: [ 2968.676081] rk29_sdmmc_change_clk_div..1961.. newDiv=0, newCLK=24000Khz [sdio] Oct 2 09:43:36 rk3188 kernel: [ 2968.680884] mmc1: new high speed SDIO card at address 0001 Oct 2 09:43:36 rk3188 kernel: [ 2968.682197] mmc_rescan_try_freq..1675.. ===== Initialize SDIO successfully. [mmc1] Oct 2 09:43:36 rk3188 kernel: [ 2968.683075] Linux Kernel SDIO/MMC Driver Oct 2 09:43:36 rk3188 kernel: [ 2968.684245] dhdsdio_probe : no mutex held. set lock Oct 2 09:43:36 rk3188 kernel: [ 2968.684474] FW_PATH = /system/etc/firmware/fw_RK901a2.bin Oct 2 09:43:36 rk3188 kernel: [ 2968.684489] NVRAM_PATH = /system/etc/firmware/nvram_AP6210.txt Oct 2 09:43:36 rk3188 kernel: [ 2968.684966] F1 signature read @0x18000000=0x1591a962 Oct 2 09:43:36 rk3188 kernel: [ 2968.703700] DHD: dongle ram size is set to 245760(orig 245760) Oct 2 09:43:36 rk3188 kernel: [ 2968.705313] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK901a2.bin Oct 2 09:43:36 rk3188 kernel: [ 2968.706597] wl_create_event_handler thr:7bf created Oct 2 09:43:36 rk3188 kernel: [ 2968.707773] wl_create_event_handler thr:7bf started Oct 2 09:43:36 rk3188 kernel: [ 2968.708753] p2p0: P2P Interface Registered Oct 2 09:43:36 rk3188 kernel: [ 2968.708914] dhd_attach thr:7c1 created Oct 2 09:43:36 rk3188 kernel: [ 2968.709061] dhd_attach thr:7c1 started Oct 2 09:43:36 rk3188 kernel: [ 2968.709226] dhd_attach thr:7c2 created Oct 2 09:43:36 rk3188 kernel: [ 2968.709491] dhd_attach thr:7c2 started Oct 2 09:43:36 rk3188 kernel: [ 2968.709678] dhd_attach thr:7c4 created Oct 2 09:43:36 rk3188 kernel: [ 2968.709821] dhd_attach thr:7c4 started Oct 2 09:43:36 rk3188 kernel: [ 2968.710610] bcmsdh_set_drvdata Enter Oct 2 09:43:36 rk3188 kernel: [ 2968.711359] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33 Oct 2 09:43:36 rk3188 kernel: [ 2968.711622] dhdsdio_probe : the lock is released. Oct 2 09:43:36 rk3188 kernel: [ 2968.711786] Oct 2 09:43:36 rk3188 kernel: [ 2968.711790] Dongle Host Driver, version 1.28.13.1.1 (r) Oct 2 09:43:36 rk3188 kernel: [ 2968.711799] Compiled in drivers/net/wireless/bcmdhd on Mar 18 2013 at 10:57:53 Oct 2 09:43:36 rk3188 kernel: [ 2968.712728] rk29sdk_wifi_power: 0 Oct 2 09:43:36 rk3188 kernel: [ 2968.915454] wifi shut off power Oct 2 09:43:36 rk3188 kernel: [ 2968.915540] =========== WLAN placed in RESET ========
Code:root@rk3188:/# iwconfig lo no wireless extensions. sit0 no wireless extensions. ip6tnl0 no wireless extensions. eth0 no wireless extensions. p2p0 IEEE 802.11bg ESSID:off/any Mode:Managed Access Point: Not-Associated Retry long limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:on [B]wlan0 IEEE 802.11 ESSID:"" Mode:Master Frequency:2.412 GHz Access Point: Not-Associated Bit Rate:65 Mb/s Tx-Power:32 dBm Retry min limit:7 RTS thr:off Fragment thr:off Power Managementmode:All packets received Link Quality=5/5 Signal level=0 dBm Noise level=0 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0[/B]
Code:Oct 2 09:45:26 rk3188 kernel: [ 3078.560697] CFGP2P-ERROR) wl_cfgp2p_do_ioctl : wl_cfgp2p_do_ioctl: IOCTL req 0x8b03 on p2p0 I/F. Ignoring. Oct 2 09:45:26 rk3188 kernel: [ 3078.570786] CFGP2P-ERROR) wl_cfgp2p_do_ioctl : wl_cfgp2p_do_ioctl: IOCTL req 0x8b1d on p2p0 I/F. Ignoring. Oct 2 09:45:26 rk3188 kernel: [ 3078.580786] CFGP2P-ERROR) wl_cfgp2p_do_ioctl : wl_cfgp2p_do_ioctl: IOCTL req 0x8b09 on p2p0 I/F. Ignoring. Oct 2 09:45:26 rk3188 kernel: [ 3078.591251] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK901a2.bin Oct 2 09:45:26 rk3188 kernel: [ 3078.600518] Dongle Host Driver, version 1.28.13.1.1 (r) Oct 2 09:45:26 rk3188 kernel: [ 3078.600527] Compiled in drivers/net/wireless/bcmdhd on Mar 18 2013 at 10:57:53 Oct 2 09:45:26 rk3188 kernel: [ 3078.613147] wl_android_wifi_on in Oct 2 09:45:26 rk3188 kernel: [ 3078.620977] rk29sdk_wifi_power: 1 Oct 2 09:45:26 rk3188 kernel: [ 3078.874547] wifi turn on power Oct 2 09:45:26 rk3188 kernel: [ 3078.877657] =========== WLAN going back to live ======== Oct 2 09:45:26 rk3188 kernel: [ 3078.883141] sdio_reset_comm(): Oct 2 09:45:26 rk3188 kernel: [ 3078.886266] rk29_sdmmc_change_clk_div..1961.. newDiv=40, newCLK=300Khz [sdio] Oct 2 09:45:26 rk3188 kernel: [ 3078.899437] rk29_sdmmc_change_clk_div..1961.. newDiv=0, newCLK=24000Khz [sdio] Oct 2 09:45:26 rk3188 kernel: [ 3078.899884] dhd_bus_devreset: == WLAN ON == Oct 2 09:45:26 rk3188 kernel: [ 3078.903244] dhd_bus_devreset called when dongle is not in reset Oct 2 09:45:26 rk3188 kernel: [ 3078.906585] Will call dhd_bus_start instead Oct 2 09:45:26 rk3188 kernel: [ 3078.910394] F1 signature read @0x18000000=0x1591a962 Oct 2 09:45:26 rk3188 kernel: [ 3078.922535] DHD: dongle ram size is set to 245760(orig 245760) Oct 2 09:45:26 rk3188 kernel: [ 3078.926646] dhd_bus_select_firmware_name_by_chip: firmware_path=/system/etc/firmware/fw_RK901a2.bin Oct 2 09:45:27 rk3188 kernel: [ 3078.981467] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded. Oct 2 09:45:27 rk3188 kernel: [ 3079.216067] bcmsdh_set_drvdata Enter Oct 2 09:45:27 rk3188 kernel: [ 3079.221961] dhd_wlfc_init(): successfully enabled bdcv2 tlv signaling, 79 Oct 2 09:45:27 rk3188 kernel: [ 3079.232199] Firmware up: op_mode=0x0005, Broadcom Dongle Host Driver mac=00:22:f4:b6:90:f8 Oct 2 09:45:27 rk3188 kernel: [ 3079.243149] Firmware version = wl0: Dec 10 2012 15:10:32 version 5.90.195.89.1_edon/off_0xb8bf FWID 01-647dfcec Oct 2 09:45:27 rk3188 kernel: [ 3079.248934] CFG80211-ERROR) wl_cfg80211_attach_post : p2p0: p2p_dev_addr=02:22:f4:b6:90:f8 Oct 2 09:46:55 rk3188 kernel: [ 3167.771375] wl_bss_connect_done succeeded with 00:90:4c:91:00:01 Oct 2 09:46:55 rk3188 kernel: [ 3167.913111] wl_bss_connect_done succeeded with 00:90:4c:91:00:01
Code:root@rk3188:/# cat /etc/wpa_supplicant/wifi.conf ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=root update_config=1 network={ ssid="WIFI" psk="xxxxxxxx" }
Code:root@rk3188:/# wpa_supplicant -B -D nl80211 -i wlan0 -c /etc/wpa_supplicant/wifi.conf
Code:wlan0 IEEE 802.11 ESSID:"WIFI" Mode:Master Frequency:2.437 GHz Access Point: 00:90:4C:91:00:01 Bit Rate=11 Mb/s Tx-Power:32 dBm Retry min limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Managementmode:All packets received Link Quality=4/5 Signal level=-63 dBm Noise level=-92 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0
Code:root@rk3188:/# dhcpcd -A wlan0 root@rk3188:/# dhcpcd.sh: interface wlan0 has been configured with new IP=192.168.1.149
Code:Oct 2 09:46:55 rk3188 kernel: [ 3167.771375] wl_bss_connect_done succeeded with 00:90:4c:91:00:01 Oct 2 09:46:55 rk3188 kernel: [ 3167.913111] wl_bss_connect_done succeeded with 00:90:4c:91:00:01 Oct 2 09:47:47 rk3188 dhcpcd[2015]: wlan0: dhcpcd 3.2.3 starting Oct 2 09:47:47 rk3188 dhcpcd[2015]: wlan0: hardware address = 00:22:f4:b6:90:f8 Oct 2 09:47:47 rk3188 dhcpcd[2015]: wlan0: DUID = 00:01:00:01:19:de:14:5f:00:22:f4:b6:90:f8 Oct 2 09:47:47 rk3188 dhcpcd[2015]: wlan0: broadcasting for a lease Oct 2 09:47:48 rk3188 dhcpcd[2015]: wlan0: offered 192.168.1.149 from 192.168.1.1 Oct 2 09:47:57 rk3188 dhcpcd[2015]: wlan0: leased 192.168.1.149 for 3600 seconds Oct 2 09:47:57 rk3188 dhcpcd[2015]: wlan0: adding IP address 192.168.1.149/24 Oct 2 09:47:57 rk3188 dhcpcd[2015]: wlan0: adding default route via 192.168.1.1 metric 0 Oct 2 09:47:57 rk3188 dhcpcd[2015]: wlan0: adding route to 169.254.0.0/16 metric 0 Oct 2 09:47:57 rk3188 dhcpcd[2015]: wlan0: exiting Oct 2 09:47:57 rk3188 dhcpcd.sh: interface wlan0 has been configured with new IP=192.168.1.149
Code:root@rk3188:/# ifconfig wlan0 wlan0 Link encap:Ethernet HWaddr 00:22:f4:b6:90:f8 inet addr:192.168.1.149 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::222:f4ff:feb6:90f8/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:87 errors:0 dropped:41 overruns:0 frame:0 TX packets:14 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:17684 (17.2 KiB) TX bytes:2683 (2.6 KiB)
Yes, I know this way I got it works is a "tricky" and is not a "true result" I wanted to get! So I will continue my investigations to get the kernel compiled with correct f***g module and run well!!!
Did you use my source?
How did you tell the source to make the AP6210 module?
When I run it the only modules I get are MALI related.
EDIT:
Ohhhhh I get it now.
Just put /lib/modules/rkwifi.ko in /etc/modules to load on startup.
Then (if you have a DE) install WICD to take care of DHCP and WPA_Supplicant.
I'm trying to recompile the module to look in /etc/firmware instead of /system/etc/firmwareBuy me a beer with
or
tyeo098,
1) Yes, I have used your kernel sources from GitHub.
2) I didn't make AP6210 module - I just use compiled rkwifi.ko and firmware.
And by the way
Code:#cat lib/modules/3.0.72+/modules.builtin | grep rk_wifi kernel/drivers/net/wireless/rkwifi/rk_wifi_config.ko
3) I know about /etc/modules and have not DE installed - but for now I will use utils 'by hand".
EDIT: Guess i should read instructions
iwconfig seals the deal.
I modified the kernel to look in /etc/firmware and not /system/etc/firmware.
Muuuuch better.Last edited by tyeo098; 02 October 2013, 17:49.Buy me a beer with
or
I have Wifi working 100% now.
Anything network related (like internet browsing) requires root permission, so I need to update that.
Pushed new firmware location to git.Last edited by tyeo098; 03 October 2013, 00:43.Buy me a beer with
or
Originally posted by mmm123 View PostI have an idea why it is not working.
RK3188 chip has 2 HDMI ports.
Manufacturer of the board decides which port to use.
My images are for K-R42 / CS918 / MK888 / Jesurun DX05. These devices have HDMI0 connected to TV out and HDMI1 connected to HDMI port.
If both ports are enabled, linux chooses to use first port (HDMI0), because it is first and TV-out doesn't have a mechanism to detect if there is actually TV connected to it. Because of that, in my image HDMI0 is disabled and HDMI1 is default.
I guess on your device HDMI port is connected to HDMI0, and as result you don't see anything on display.
Another possible reason is DDR frequency. On devices mentioned above DDR frequency is 400Mhz, but it is possible, that your device uses other type of DDR and it is DDR300 (ddr300 is lower setting)
If you want to try, i can build another image with DDR freq set to 300 and default HDMI port 0.
Originally posted by miniditu View Postyour images work for my device, i found its hostname in my router. but show nothing on display. please build it . thanks.
<4>[ 0.000000] DDR DEBUG: version 1.00 20130712
<4>[ 0.000000] DDR DEBUG: DDR3 Device
<4>[ 0.000000] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.000000] DDR DEBUG: init success!!! freq=300MHz
<4>[ 0.000000] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=0x4, DGSL=0 extra clock, DGPS=360
<4>[ 0.000000] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.000000] DDR DEBUG: DRV Pull-Up=0xb, DRV Pull-Dwn=0xb
<4>[ 0.000000] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.268198] lcdc0 is used as external display device contoller!
<6>[ 0.274836] lcdc1 is used as primary display device controller!
<4>[ 0.731118] lcdc1:reg_phy_base = 0x1010e000,reg_vir_base:0xf70a0000
<4>[ 0.731310] rk3188 lcdc1 clk enable...
<4>[ 0.756476] rk3188 lcdc1 clk disable...
<4>[ 0.789784] rk3188 lcdc1 clk enable...
<4>[ 0.789828] lcdc1: dclk:99000000>>fps:56
<6>[ 0.789861] rk30-lcdc rk30-lcdc.1: rk3188_load_screen for lcdc1 ok!
<6>[ 0.789906] lcdc1 wakeup from standby!
<6>[ 0.789936] lcdc1 win0 open,atv layer:1
<4>[ 0.803994] rk3188 lcdc1 probe ok!
<4>[ 0.804081] lcdc0:reg_phy_base = 0x1010c000,reg_vir_base:0xf70a4000
<4>[ 0.804241] rk3188 lcdc0 clk enable...
<4>[ 0.829331] rk3188 lcdc0 clk disable...
<4>[ 0.829927] rk3188 lcdc0 probe ok!
<4>[ 3.179904] hdmi connect to lcdc0
<4>[ 3.179935] rk3188 lcdc0 clk enable...
<4>[ 3.180024] lcdc0: dclk:74250000>>fps:60
<6>[ 3.180090] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
<6>[ 3.180201] lcdc0 wakeup from standby!
<6>[ 3.180267] lcdc0 win0 open,atv layer:1
<4>[ 3.180324] lcdc0: dclk:74250000>>fps:60
<6>[ 3.180386] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
<6>[ 9.118079] lcdc1 win1 open,atv layer:2
<6>[ 9.118131] lcdc1 win1 closed,atv layer:1
<6>[ 9.368887] rk30-lcdc rk30-lcdc.1: blank mode:0
<6>[ 115.441410] DWC_OTG: frame_number 0x1f24, start 0x1f1f, complete: 1hdmi connect to lcdc0
<4>[ 116.413291] lcdc0: dclk:74250000>>fps:60
<6>[ 116.413339] rk30-lcdc rk30-lcdc.0: rk3188_load_screen for lcdc0 ok!
<6>[ 3.005425] rk610_hdmi 4-0046: rk610 hdmi i2c probe ok
Code:complete: 1hdmi connect to lcdc0
Code:<6>[ 0.268198] lcdc0 is used as external display device contoller! <6>[ 0.274836][B] lcdc1 is used as primary display device controller![/B]
Buy me a beer with
or
Little Lost...
Hi guys,
it sounds like some really good progress has been made. But I'm struggling to keep up on where the latest firmware can be found to put linux (with working wifi) onto an Rk3188 which has the AP6210 wifi chip.
It sounds like some of you have done it, but by compiling your own kernels? Is there a simple firmware version I can download from somewhere and try it out?
Best regards
Marty
Dear Leola .. pls help
Originally posted by leolas View PostWhat is the problem you found to make the recovery? If I can help only tell me.
OR
Please help....
There are currently 1889 users online. 0 members and 1889 guests.
