A95X PRO Android TV Box with Voice Control
    Just Got box in. Small little device. Put through tests later photos attached. Post more later.
    Main Features
    Android 7.1 OS for fast and stable running
    Voice remote control for hand free operation
    HEVC H.265 decode format, saving half bandwidth
    ● Amlogic S905W CPU, 1.5GHz quad-core ARM Cortex-A53 processor
    ● Support 4K Ultra HD resolution
    ● Mali-450 GPU
    ● 2.4GHz WiFi
    ● 2G DDR3 RAM + 16G ROM
    ● Remote control is powered by two AAA batteries ( not included )
    Amlogic S905W Android 7.1 2GB RAM + 16GB ROM 2.4G WiFi 100Mbps H.265 Support Youtube 4K + Netflix HD
    Main Features
    ● Mali-450 GPU
    ● 2.4GHz WiFi
    ● Remote control is powered by two AAA batteries ( not included ) Specification
    Type: TV Box
    GPU: Mali-450
    System: Android 7.1
    CPU: Amlogic S905W
    Core: Cortex A53,Quad Core
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G
    Max. Extended Capacity: TF card up to 64GB (not included)
    Decoder Format: H.265
    Video format: 3GP,4K,AVI,DIVX,FLV,H.264,H.265,M4V,MKV,MP4,MPEG2, MPEG4,PMP,RM,RMVB,VC-1,VOB,WMV
    Audio format: AAC,APE,FLAC,M4A,MP3,OGG,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: No
    Power Supply: Charge Adapter
    Interface: 3.5mm Audio,DC Power Port,HDMI,LAN,SPDIF,TF card,USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: Others
    Power Type: External Power Adapter Mode
    Product weight: 0.0770 kg
    Package weight: 0.2920 kg
    Product size (L x W x H): 9.30 x 9.30 x 1.50 cm / 3.66 x 3.66 x 0.59 inches
    Package size (L x W x H): 18.50 x 12.70 x 5.00 cm / 7.28 x 5 x 1.97 inches
    Package Contents: 1 x A95X Pro Android TV Box, 1 x Voice Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
    Click image for larger version  Name:	20180502_181002-768x1024.jpg Views:	1 Size:	75.6 KB ID:	723650Click image for larger version  Name:	20180502_234112-768x1024.jpg Views:	1 Size:	93.8 KB ID:	723651Click image for larger version  Name:	20180502_234137-768x1024.jpg Views:	1 Size:	154.7 KB ID:	723652Click image for larger version  Name:	20180502_234124-768x1024.jpg Views:	1 Size:	178.1 KB ID:	723653Click image for larger version  Name:	20180502_234224-768x1024.jpg Views:	1 Size:	116.7 KB ID:	723654Click image for larger version  Name:	20180502_234215-768x1024.jpg Views:	1 Size:	111.6 KB ID:	723655Click image for larger version  Name:	20180502_234236-768x1024.jpg Views:	1 Size:	181.0 KB ID:	723656
    Some Vents so next
    Will post more once I get internet back in at house Funny finally got some boxes to play with and modem from internet provider crapped out.
      Great!!!!!!!!!!!!!!!
        Not fair you received your box and I only got an email telling me they are back ordered............. hahaha.....
        Anyway, looking forward to your review. How is the temp?? How do you like the remote? Can you press the "mic" button and the "assistant" ask you what you want???
        thanks...
        • scooter2014
          scooter2014 commented
          Editing a comment
          It has wifi set up soon as it boots so cant get past that until wifi fixed. Remote feels cheap but seems to work ok. Dont feel any heat has vents so think fine I'll hopefully get to play with tonight once router delivered.
        Finally on line. Lol
        The remote voice not working for me. Box does get bit warm running. Its android TV interface. HD YouTube and Netflix's confirmed working.
        so short summary
        remote kinda poor but does the job switch to mouse mode works
        voice no go here. Assistant shows up but cant hear anything I say.
        speed ok
        everything working
        loading and testing some more
        nexflicks hd
        you tube hd.
        kodi.
        comes pre loaded with few addons they all work fine.
        more to come.
          so short summary
          speed ok
          everything working
          nexflicks hd
          you tube hd.
          kodi.
          more to come.
          That doesn't sound good about the voice remote not working. That is the only reason I purchased this box, for the Voice remote...........
          • scooter2014
            Editing a comment
            Hopefully it glitch as I wanted it as well or mines defective who knows at this point. Try yours if mines bad. I'll trade ya @
          Reboot your box. I just received my new Voice remote and the voice did not work. Rebooted the box and it started to work.
            My new $7.42 USD Voice Remote.
            • trebor
              trebor commented
              Editing a comment
              Looks Pretty good for the price paid and does the job. Excellent
            Ok want to trade remotes lol?
              I am hoping the remote works when I get my box........... But YOU have to figure out how to get the Voice remote to work before I receive my box.
ID:	724688Click image for larger version
ID:	724689Click image for larger version
ID:	724690Click image for larger version
ID:	724691Click image for larger version
ID:	724692Click image for larger version
ID:	724693Click image for larger version
ID:	724694Click image for larger version
ID:	724695 Some bits and pieces
                case in screws carefully pull side edge back on both sides pops open.
                different wifi.
                Samsung nan
                hmmmm 4 post for add on when I finally brick it.
                A RESET SWITCH SPLURGE THEY DID
                  Voice remote still NOT working?????
                    Nope power off /on not working either. But box running playing everything no issues. Sd card works runs about 22000 on antutu. So not a shabby but fir the price given level one ect
                      Update voice control working. Was button issue was stuck all good press and hold...... I reset and found a bit of a set up issue. If you do not have wifi you can not finish the set up but. Think I find work around but going to wipe box again to confirm it works .
                        Glad you got the voice working.
