A95X PRO Android TV Box with Voice Control
Originally posted by brunomsg View PostSomeone with this A95X PRO box could send me their /system/build.prop file?
Originally posted by brunomsg View PostSolvedmine back to life
A guy sent me a twrm backup of their and its all ok now
Thanks!!
hcardoso483
posted by brunomsg
I think that I did it well. After choose that option it shows the A95X logo on gthe tv, like "stucked" in there, right?
Mate if you are getting trouble doing this I can send you a TWRP recovery for you to make a backup and send that backup to me then I will fix it for you and send you the backup fixed
Hey hcardoso483
I just got my box mate and I am looking for twrp recovery for this . No were to find can you send me a link for that please .
I will be grateful .l hate to build the box and if is happen something start again ,
Thank you mhate
Originally posted by brunomsg View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by brunomsg View PostYou need to boot with twrp and restore with this...
Any more ideas???
Should I name the zip file something special, like update or something???MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Right now, I am running the Mecool M8S Pro W on my box. I am making a backup using TWRP, and then I will compare the files in both backups and try swapping files to see if that will work.
Got back to stock firmware, thanks to Brunomsg for providing the TWRP backup. HOWEVER, I think I lost my Widevine DRM level 1 keys forever by using the procedure that I used.
TWRP would NOT install his backup as it was, so I had to make some mods. I used TWRP to make a backup of my existing firmware, then I copied all of the files from his download, to my newly created backup file. Then using that modded backup, TWRP saw it and restored it. Now it appears that I am back to the firmware that the box shipped with.
But, since I used his files, including the boot, bootloader, recovery, etc. files, I was concerned that I would lose the DRM keys, and it appears that I did, and they will be gone forever...Last edited by clarkss12; 04 June 2018, 17:16.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by micara View PostSorry guys for my English Im looking for the twrp recovery image to install in this box if someone has a link or give me directions where to get it I will be grateful
thank youMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2548 users online. 0 members and 2548 guests.
