here is my test
my gt1 ultimate 3 gb ram has fake ram. does that mean i heve defective processor too?
i checked the ram with fill ram app. it crashed at %60 . so i have a box with 2 gb ram. i read something about these boxes have some defective processors . if i have fake ram does this mean the processor is defective too
here is my test
Tags: None
Don't forget that you OS also uses ram. Anda it will kill que ram app before you get the full 3gb of ram. What intrigued me was that the system killed the app when you still had 1gb of ram available. I tried the app with mine and it kept killing background apps untill it only had the ram used by the system. It used 2.3 or 2.4gb of ram untill it was killed. What version is your beelink?
my serial is a706dsbf81289
i think fake reporting of 1 gb will make it just like that.
it was ten years ago , there were lots of cheap 128gb 64gb sd cards on ****. too good to be true , right
of course i tried
the os was reading 128 gb. after actual 512mb or so system was overwriting the old data . file structure was showing intact but the files were reporting corrupted.
shocking a somewhat big company do that.
edit : the app is supposed to cause low memory notification
Originally posted by kenanal View Posti checked the ram with fill ram app. it crashed at %60 . so i have a box with 2 gb ram. i read something about these boxes have some defective processors . if i have fake ram does this mean the processor is defective too
here is my test
https://youtu.be/m0gr-lf-Gxs
For exact parts just create the bootloader log.
kenanal
a few days ago I got a new Beelink GT1 Ultimate, which I bought on e..b..a..y DE. Android 7.1 (FW 708D0) preinstalled, 3GB DDR4, S / N B706DBGG00166 32G, all good. Then I opened the case of the box and made a serial connection to the PC via uart-> usb adapter. Here is the log
BL2 reports the following information:
Code:[LIST=1][*]DDR3 chl: Rank0+1 @ 912MHz - PASS[*]Rank0: 1024MB(auto)-2T-13[*]Rank1: 1024MB(auto)-2T-13[/LIST]
Code:[LIST=1][*]U-Boot 2015.01-ge6b8bc9 (Feb 09 2018 - 10:09:37)[*]DRAM: 3 GiB[/LIST]
If you install normal uboot, it shows the following:
Code:[LIST=1][*]DRAM: 2 GiB[/LIST]
did you check the mmc . if they are doing this , 32gb mmc is suspect too ,
and processor too in my opinion. cores are downclocked to keep it cool they said, who knows
i bought this 6 months ago. gearbest probably will try to make it my problem. altough it is as clear fraud as it gets
the thing is , i may be ok with 2gb ram if os reads the correct ram and it has somewhat decent processor
No, the CPU is OK, it's a real AML-S912.
Code:GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RCY:0;EMMC:0;READ:0;
GXM = Q200 / Q201 - Platform = S912 CPU. In our case it is Q201.
eMMC full size I test a little later, it will use a different u-boot test version.
There are currently 2460 users online. 0 members and 2460 guests.
