Also try using USB 2 ports rather than USB 3.
N00b: Device won't show up on TV (HDMI or Composite)
I'm still getting the same errors, but to prove that there is life in the device I posted it's operation. I tried with two cables, one from my smartphone and one from an external drive. I will ask my g/f for her cable to see what happens. I tried to update drivers and chose the folder. it prompts "System already has the latest driver". So it doesnt update it.
Regards,
Paul
Hi ,
first please post Pictures of your PCB , both Sides , nearby , good light ,
second do you have a Win7 PC , better for RK3188 and older , and was
a SDCard insert while you tried to connect with Flashtool ??? ,
always without SDCard when you want to flash , please what USB port
did you use , u have one one the side one back and a smaller OTG port ,
is this correct ???
greetings / gefattern
- OK, Included.
- No, I have a Win10 Laptop and Desktop, will try to get a Win7 to test.
- No, I installed it to verify that everything is showing up/detected on my File Explorer
- I tried my USB 3 and USB 2.0 port, Using the small OTG port on the box
is this correct ???
greetings / gefatternYou may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
Hi ,
thanks for Pictures , but i mean PCB (otherSide) , but not so important , only look if you can find
something like a "reset" hole under the Box , maybe the one one PCB is not correct ???
Normal it must work with Win10 , but Win7 , i find , always better for older Boxes , is the cable u
use the one that came with the Box ??? as possible take this one .
Please uninstall the Drivers and try it with Drivers 4.3 or 4.4 (use Google) , or i can upload later
if u want , dont use the USB3 from PC , dont work , for Driver install on Win10 u can look on YT
for some helping Videos , sometimes good to see how it must , please try the other USB2 ports
of the Box , too , and can u once discribe what u exactly did while connecting and trying to flash
your Rom , thanks , (Picture of the cable) as possible ,
grettings / gefattern
Believe this shit or not, It was a WIndows 10 problem. I found in my closer a REALLY OLD WinXP laptop and it read the device, and I flashed the factory ROM. It went successful. I ejected the USB device. Then went to the TV. Connected HDMI and pushed the power button. It turned blue but nothing happens. The TV HDMI input says No Signal, and the Blue LED would not toggle (turn off or on). Before it would go red but now it does nothing.
Originally posted by pauldays View PostBelieve this shit or not, It was a WIndows 10 problem. I found in my closer a REALLY OLD WinXP laptop and it read the device, and I flashed the factory ROM. It went successful. I ejected the USB device. Then went to the TV. Connected HDMI and pushed the power button. It turned blue but nothing happens. The TV HDMI input says No Signal, and the Blue LED would not toggle (turn off or on). Before it would go red but now it does nothing.
try it again on other TVs , if it not helps , a Hardware Problem , the HDMI Port ??? , maybe time to buy a better Box , how long in use ???
My UT3 bricked after 4Years of using , not bad , my Problem is a bricked /corrupted IDB , i can get no Output on TV too ,
the only thing you can do is try some other compatible Roms ,
There are currently 2014 users online. 1 members and 2013 guests.
