Some cwm installable zips.
    This zip can be used to install a rom or only one part of it(kernel.img, boot.img or system.img). It is a zip model and you need to add the zip the files you want to flash.
    http://www.freak-tab.de/leolas/cwm/c...-installer.zip
    What is this?
    Is very simple, if you have your cwm recovery installed you can use this zip to flash other kernel.img, a system.img from other rom, other boot.img or any combinations, for example flash a boot and a kernel; a boot.img and system.img, or a complete rom (boot.img;kernel.img and system.img).
    How can I use it?
    You need to select what files you want to flash drag and drop them inside the zip, YOU DON'T HAVE TO UNZIP IT, ONLY DRAG&DROP THE IMG FILES INSIDE.
    In windows you need to have winrar(pay app) or 7Zip(http://www.7-zip.org/) installed in your windows, files added by windows unzipper will fail.
    In Linux you can use The gnome Archive manager.
    kernel have to had the name kernel.img
    boot have to had the name boot.img
    system have to had the name system.img
    Only drag and drop inside the zip the file you want to flash with the correct names.
    Some examples:
    1. You want to flash Finless 1.6 for T428 at 1080p. And don't want to use the pc, you can unzip the Bob Finless rom, take from it boot1080p.img; kernel1080p.img and system.img.
    Then you rename:
    boot1080p.img-->boot.img
    kernel1080p.img-->kernel.img
    system.img don't need to be renamed, it has the right name .
    Now we got the zip, and we Drag&drop the files inside the zip. We boot in recovery mode and select install zip from sdcard (external sdcard, depending where you have the zip) then we select the zip and thats all. (see recommendations in this post)
    2. Now we want to test a great new kernel made by hoaby for our device, but we don't want to connect the stick to the pc, enter in bootloader mode and use the pc to flash it, so lets download the kernel made by hoaby called kernel-videofixed.img, rename it to kernel.img, drag&drop it to the zip, enter in recovery mode, and flash it, reboot and you got it Is not easy?
    3. We are using leolas-rom for qx1, but leolas (am I?) got wrong and he made a big fail inside his boot.img (WTF I will kill him). Instead of flash the entire rom, we can use cwm to flash only the fixed boot.img. Download boot-fixed.img and rename it to boot.img, drag&drop it inside the zip and flash it using cwm. Seems easy.
    The bad:
    We cant resize partitions using cwm (at least I didn't discover how do it, and I tried it a lot of times). So the img files must be equal or smaller that the destination partition, we cant flash a 10,6Mb kernel.img in a 9Mb partition. Usually it will not happens, partitions usually are bigger enough, but I want to advice you.
    We can flash only boot.img, system.img kernel.img, we cant flash the loader, format the nand, resize partitions, so if you want to use a 2Gb for the app partion and you have actually only 1Gb. You need to use the pc for resize it.
    If we need to hard format nand, we need to use the pc too.
    Recomendations.
    Allways make a nandroid backup on an external sdcard before flash anything, with it, you can restore your device to the initial state without any problems.
    When we change the full rom I suggest to do a wipe data/factory reset
    after flash the rom using cwm, if not we are mixing data and configurations from the old rom in the new rom. It can work, but it can lags, fc, etc...
    If you only flash a new kernel or boot.img, usually this is not necessary, but if you experiment some strange lags, or force close in apps, at least wipe cache and dalvick cache (in advanced options), if the force close or lag continue, sorry but a factory reset will be the solution.
    Wiping cache and dalvick you dont loose the apps installed in your device, but after a wipe data/factory reset you will loose them.
    I suggest you made a copy of the zip file and keep the original zip, try dont to flash first a kernel, after a system, etc ... Use it, and then to make other task use other copy of the original zip.
    Enjoy, and if I can help only tell me. Of course, feedback if you can please, and if you found some corrections or contributions, they will be always welcome
    leolas
    My devices:
    Gearbest.com)
    Reserved
    My devices:
    Gearbest.com)
      ReservedII
      My devices:
      Gearbest.com)
        Good stuff
        I make extensive use of this when developing ROMs, it saves me a lot of time.
        I keep a known working install.zip on my tab for when I get it wrong:-)
        :thumbup:
        Last edited by 900supersport; 09 September 2013, 22:45. Reason: corrected poor english
        900Supersport
        freaktab developer
          Re: Some cwm installable zips.
          Originally posted by 900supersport View Post
          Good stuff
          I make extensive experience we of this when developing ROMs, it saves me a lot of time.
          :thumbup:
          leolas
          My devices:
          Gearbest.com)
            Kernels
            Flashing kernels, just got alot easier. Thanks, much.
              Thanks leolas for another excellent post
              Live as if you were to die tomorrow. Learn as if you were to live forever
                Very useful CWM template , thanks very much.
                  Thanks to all. If someone has more ideas for more zips only tell me. I am doing 1 to format sdcard, and other like this one for add kernel modules to the stick.
                  And working in a couple of scripts to boot in picuntu (or any Linux arm distro) or restore cwm
                  leolas
                  My devices:
                  Gearbest.com)
                    GREAT!
                    Thank you so much for your hard work.
                      in some days will try this!
                      thanks leolas
                      to make zip file, just winzip?
                        Super !
                        Great work again !
                        Device:Tronsmart MK908 v1,Cozyswan S400
                        Rom: Finless Bob v1.6,Stock Rom
                        Kernel:Finless Bob v1.6
                        CWM-Recovery:by Leolas
                          thanks leolas
                          Nop, in the first post winrar or 7zip.
                          Originally posted by Torkemada View Post
                          Super !
                          Great work again !
                          leolas
                          My devices:
                          Gearbest.com)
                            worked for me cheers!!
                              Awesome
                              Thanks Leolas, this method worked for me too. I installed the Riley ROM on the Video Mini one by following your instructions.
